79 TA, 10 Bolt rear end, highway gears, looking to step up - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-01-2007, 04:42 AM
Gladis's Avatar
So I've got 2:73's I want to step up to be buddy's scamp with 3:55s. So after a bunch of procrastinating I go to see what a shop would charge me to put in different gears. I don't know anything about gears, no one I know knows, and I don't have the time to learn right now. So I ask the shop what he would charge me, he tells me that my 2:73 rear end cannot be changed to anything above a 3, because it won't fit. I've never heard of this. Why couldn't I buy gears and stuff off summit for a 10 bolt, and have him install them?
Old 04-01-2007, 07:34 AM
Lonestar's Avatar
"May the Schwartz be with you"
Last journal entry: Finally getting going...
You need a new carrier to go to those gears.
Old 04-01-2007, 12:23 PM
Gladis's Avatar
so he is right, where can I find information on what size carrier takes what gears, I know I may sound stupid right now, but I am.
Old 04-03-2007, 08:19 PM
The carrier break is 2.56-2.73 on an 8.5" 10-bolt, and that's the only rear end they used on a '79 Firebird. Your carrier is "3-series", and will work fine with 3.55's.
Rear end swap required & I'm cunfussed datsun dale Transmission - Rearend 8 12-17-2008 09:03 AM
Can rear end gears be swapped at home? (8.5" 10 bolt) Warrant Transmission - Rearend 6 09-22-2006 09:55 AM
bolt on rear end Paul51 Transmission - Rearend 7 03-04-2006 11:13 AM
10 Bolt Rear End TORI1 Transmission - Rearend 1 12-29-2005 12:02 PM
Rear end swap problems datsun dale Transmission - Rearend 1 12-17-2002 10:50 PM
