79 TA, clunk, clunk, clunk sounds under hard steering - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-10-2007, 06:01 PM
Gladis's Avatar
My steering has been doing some strange things. It lags, like I turn the wheel, then the car turns a little later. It's not like there's a lot of dead space, it's like it takes the car a little less then a second to respond my steering. It's like a told my friend, it used to feel like I was turning the wheel through water, now it feels like I am turning it through air. Just now, I came around the corner, turning right, and clunk, clunk, clunk, coming from the right front. Any ideas about what is going out on the steering?
Old 04-10-2007, 06:16 PM
russlaferrera
Last wiki edit: Threading tips
Wiki Edits: 2
Hard Steering
Jack it up, take a look see. You probably have a worn steering part, that is making the noise. Check the steering linkage for looseness and idler arm, ball joints for excessive play. You can also check the rubber bushings on the sway bar and upper a frames.
Old 04-10-2007, 06:20 PM
brian0605's Avatar
mostly confused
Last journal entry:
I would be inclined to look very closely at the wheel bearing!! I would also look at everything else as well but it just sounds like a wheel bearing to me. Brian
Old 04-13-2007, 06:43 PM
Bigolotava's Avatar
I had a buddies car in Hawaii that did something similar to what you describe. It started out the same way... only he had to eventually turn the steering wheel about 1 to 1-1/2 turns to get the wheels to start turning! The problem was later traced to the steering box... Once it was replaced it was fine. Somebody had tried to rebuild it for him and messed up the little ball bearings that cradle the spool in there. I replaced my leaky unit in my '79 Formula with one from NAPA for about $185. It even had the nice, quick 2.75 turns lock to lock ratio!
Good Luck and don't drive it too long in the current condition... Your life (plus whoever's lives you have a head-on collision with) are worth having it checked out!
Old 04-13-2007, 08:47 PM
Gladis's Avatar
the clunk sound is rubber bushing that's gone missing(between the frame and unibody, if that makes sense), the steering is getting more worn, but the idle was too low, so when I was coasting the power steering wasn't getting enough to make the steering fluid. It's still probably needs a few things replaced, but it looks like i am going to try to buy a different car. Who knows though. Thanks for the info, one question though. Steering box, where and what is that? I am a partard.
Old 04-14-2007, 11:45 PM
Bigolotava's Avatar
The steering box (steering gear) is located at the end of your steering wheel and converts the rotation of your steering wheel to L/R motion in the front wheels. If you pop the hood open and look on the driver's side firewall, you'll see the steering shaft that extends from the steering wheel... follow it down to the front of the car and you'll see the steering box connected to it. You'll also notice the hoses from your power steering pump are connected to it too which provide the power assist when the engine is running.
Take Care!
Old 04-23-2007, 05:51 PM
Gladis's Avatar
replaced the wheel bearings and the race thingys they run on, but I'm still getting the clunk clunk clunk sound, also replaced the frame bushings too. Rides a lot better, steers a lot better, but still on those hard left turns it goes clunk clunk clunk. I can feel it too, through my rm that's usually resting on the center console.
Old 04-23-2007, 06:19 PM
1ownerT's Avatar
Home School Valedictorian
Last wiki edit: Health and safety in the shop or garage Last photo:
Wiki Edits: 4
You could replace parts that may not need replacing and eventually find it. I would do a complete front end check, suspension and steering. There are many possibility's worn or missing control arm bushings, missing control arm shims, bad ball joints, there are so many things.
If you don't know how to check everything, take it to a couple of shops and have them check it and compare the parts list's, get a list and post back on how to fix.
Old 04-25-2007, 08:40 AM
Bigolotava's Avatar
I agree with 1ownerT, get the car checked out by a competent repair facility. I've had good luck with Goodyear in my area.
And at the risk of sounding sexist, I would highly recommend you have a boyfriend, brother or Dad go in with you, as it seems all these places tend to take advantage of women, particularly if you're not the most mechanically proficient... Either way, get it checked out and fixed as you don't want to take a chance on something so important to the safe operation of your car.
Best of luck getting it fixed! Let us know what the problem was. The '79T/A is a wonderful car to drive when the front end end is tight and accurate!
Old 04-25-2007, 12:32 PM
Gladis's Avatar
ha ha ha, I'm a dude, my car's named gladis. ha ha ha
Old 04-25-2007, 02:03 PM
Bigolotava's Avatar
Sorry DUDE!!! (Really!)
My wife gets the "treatment" anytime she takes her car in for work and I'm not there, thus the advice. Funny how many times they want to perform that fuel injection cleaning service!
Anyhow, get your T/A's front-end checked out professionally and let us know what they found... I'm curious as to what it might be. Barring the steering box, I would hazard to guess the upper control arm bushings followed by the lower ball joints. GM recommends servicing the uppers anytime the lowers are changed, so don't be surprised if they suggest replacing them too. The idler arm, center link and tie rod ends could also be suspect given the age of your T/A and the care (or lack of care) it's received over the years.
Good Luck!
Old 04-29-2007, 09:22 PM
brian0605's Avatar
mostly confused
Last journal entry:
You need to check the rearend, I think that is more than likely where you will find the problem. good luck. Brian
Old 04-30-2007, 06:03 PM
Gladis's Avatar
ya definently my tranny is way over on the passeger side, so when I turn left hard it swings into the wall there and beats on the body. So I'm thinking new tranny mounts.
Old 05-01-2007, 07:34 AM
brian0605's Avatar
mostly confused
Last journal entry:
yeah that'll do it!! might want to check engine mounts while you're at it.Brian
79 TA headers GearHead69 Engine 1 07-27-2005 07:09 PM
Classic Hot Wheels Good Condition or New COndition ArchonRacing Engine 2 02-22-2005 12:19 AM
Hotrodders Knowledge Cluster: Power Steering Conversions Jon Suspension - Brakes - Steering 0 09-03-2003 11:20 PM
