Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 79 TA, clunk, clunk, clunk sounds under hard steering
Old 04-10-2007, 06:16 PM
russlaferrera russlaferrera is offline
russlaferrera
Last wiki edit: Threading tips
Wiki Edits: 2
Hard Steering
Jack it up, take a look see. You probably have a worn steering part, that is making the noise. Check the steering linkage for looseness and idler arm, ball joints for excessive play. You can also check the rubber bushings on the sway bar and upper a frames.
