Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 79 TA: dash lights and tail lights fuse keeps blowing
Old 09-23-2007, 02:02 PM
78 monte 78 monte is offline
E.T. divided by $ spent= Speed
Might have a wire chaffed and grounding out somewere causeing a short.Your front parking lights and taillights should be on the same circuit if I remember right.
I think with the fuse out and the light switch off you can test between the taillight/parking filiment wire(taillight bulbs have three wires grd,brake/signal lights and taillight/parking)to ground with an ohm meter,if you get 0 resistance you have a direct short somewere.
Someone else more knowledgable in the art of auto electric will chime in I;m sure.
