79 TA disc brake problems - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-13-2007, 04:48 PM
Gladis's Avatar
The right front disc brake caliper can't come apart because one of the two bolts is stuck. I tried a lot of things to get it off, it won't come off. I suspect that I crossthreaded it somehow last time I put it on. What can I do to get this thing off?
Old 12-13-2007, 05:33 PM
Did you strip out the Allen bolt head? Is your Allen wrench or bit rounded off? Try a new wrench, or if all else fails, vise grips on the head itself. The threads are only at the head end (the rest of it's a pin), so applying heat to the bracket might help.
79 El Camino Rear Disc brake conversion Nailhead Suspension - Brakes - Steering 6 12-23-2012 09:22 PM
disc brake rotors bondsman Suspension - Brakes - Steering 6 11-30-2003 06:20 PM
79 LTD disc Brake rearend Mike Pomerantz Suspension - Brakes - Steering 2 09-11-2003 11:19 AM
will these disc brake spindles fit my Torino? jchris64 Suspension - Brakes - Steering 2 09-07-2003 05:20 AM
`33 Ford disc brake conversion Mike Humphrey Suspension - Brakes - Steering 0 02-17-2002 02:49 PM
