The rear brakes need to be bled again until no air comes out. Then adjust the rear shoes again. It sounds like the rear shoes are way out of adjustment. That can happen after the first time you brake to a stop. That action will center the brake shoe's to the drums.
NOTE; I have found (cheap, imported, made in China) brake drums, and rotors, to have too large of a center hole, where it fits onto the axle or hub, to be too large in diameter. This causes the adjustment to feel good, until you bolt on the tire and drive it. By American Made |
replaced tired drum assembly....
what did it do before? maybe the new parts aren't the root of the problem? maybe another issue led you to replace what you replaced? |
no the shoes were cracking, and it was just massive amounts of air in the line, then I also replaced the master cylinder to just make darn sure, it's almost ok now, and I'm driving anyway because I am crazy.
| 79 TA rear drum replacement | Gladis | Suspension - Brakes - Steering | 4 | 12-11-2007 10:50 PM |
| 79 TA, rear drum, riveted or bonded? | Gladis | Suspension - Brakes - Steering | 6 | 12-01-2007 05:41 AM |
| 79 TA headers | GearHead69 | Engine | 1 | 07-27-2005 07:09 PM |
| Drum Brakes Spring question | JamesRS | Suspension - Brakes - Steering | 2 | 04-12-2005 04:02 PM |
| Drum Brakes | WildOne | Introduce Yourself | 1 | 12-03-2004 09:41 PM |
