Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 79 TA: hazard, right turn signal, brake signal out
Old 12-24-2007, 02:07 AM
Gladis's Avatar
Gladis Gladis is offline
All signals and lights work for the front, left brake light, and sometimes rear left turn signal works. All rear lights come on with main lights. The almighty brown wire to the rear of the vehicle is good. The dark green and yellow are having problems, to rule out the back part of the vehicle I disconnected them in the trunk at a switch thingy and tested them with a voltometer thingy. The brown one was good, which matched the fact that the lights were on. The yellow left turn/brake light showed only a few volts. The dark green (right turn signal, brake signal) showed nothing. I traced the wire through the car, they are encased in a stout plastic tube all the way to the front. Also all fuses are good, none are blown.
Here's the big deal, I didn't quite see where the tube went but it looks like it goes from the fuse box to the steering wheel colum, where's that that thing that decides what blinks when thingy. I recently had a guy who specializes in the electric side of cars fix this, because it was starting to go. I'm thinking he messed it up(it worked correctly right after I got it back from him, who knows when it went bad), and before I get all enraged at this guy is there anything else I can check or am I on the right track to finding the error in my wiring?
