79 TA rear drum replacement - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-11-2007, 06:41 PM
Gladis's Avatar
Anything I should especially know before I replace the shoes, drums, springs and wheel cylinders?
Old 12-11-2007, 07:10 PM
31 five window
Last journal entry: grill and rear end
If you are not familiar with it ,do one side at a time so you can reference the other side. You can also take a good close up picture after you remove the drum.
Old 12-11-2007, 08:06 PM
I agree!! Thats the best way to do it if your not familiar with drum brakes. Just take your time. Good luck!!
Mark.
Old 12-11-2007, 08:26 PM
Brian_B's Avatar
Lost in the 50s!
Last journal entry: time to start body work
I still do one side at a time and I have been working on brakes since I was a kid. Too many little parts that can get turned the wrong way and too many different cars over the years.
Old 12-11-2007, 10:50 PM
Gladis's Avatar
roger thanks, I'm also going to put on Raybesto fully ceramic pads on the front, is it absolutely necessary to turn the rotors before I put them on?
1987 Iroc z steering box swap to 79 TA Gladis Suspension - Brakes - Steering 1 12-14-2007 10:07 AM
Rebuilding my Rear Drum brakes from bare backing plates!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! chevymastermind Suspension - Brakes - Steering 7 11-15-2006 06:58 PM
Rear Disc & Front Drum - Is that ok? leejoy Suspension - Brakes - Steering 4 09-05-2006 12:22 AM
Can a guy use a disc/disc master with drum rear? MM in NM Suspension - Brakes - Steering 1 12-08-2005 05:08 PM
79 TA headers GearHead69 Engine 1 07-27-2005 07:09 PM
