79 TA, TH 350 Tranny, lost park. - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-28-2007, 12:24 PM
Gladis's Avatar
So we were doing some cookies in a parking lot and came out of there onto the road, I gun it and hit some loose gravel. Car spins and hops the curb perpindicular to the road, high centered just in front of the rear wheels. The car rides 3 inches off the ground, so my mufflers are messed up, and have also stopped the emergency brakes from working because they're resting on the cable. The car when on the curb would not shift, otherwise I would've just put it in reverse an got out of there. It leaked a bunch of fluid but has stopped leaking. I've got all gears except for park. It will go into park, but can't start it there and it doesn't keep the car from moving either. So park's there, but it isn't there too. Any ideas on why I have everything but park?
Old 01-29-2007, 07:26 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
sounds like you have damaged the shifter linkage and/or the tranny it's self. I would suggest a good inspection of the under side of the car for repairs and safety issues.
Classic Hot Wheels Good Condition or New COndition ArchonRacing Engine 2 02-22-2005 12:19 AM
lost 3rd gear on th 350 Hot_Rod_Faith Transmission - Rearend 13 12-28-2003 12:39 PM
350 Turbo Tranny Problems Dans83Olds Transmission - Rearend 4 08-06-2003 01:59 PM
'79 Monte Carlo - Tranny identification bdavie Transmission - Rearend 4 05-23-2003 09:59 AM
i lost one fo those ball things in the tranny oldcarguy85 Transmission - Rearend 5 05-22-2002 01:18 PM
