79 Trans am, to shake or not to shake - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-17-2007, 12:12 AM
Gladis's Avatar
so I rednecked my current hood by screwing in the half broken shaker to the hood with deck screws. What a retard. Anyway, after i minimize the holes I put in (some sort of ghetto rigging involving bondo brand stuff) and rub all the black caulk off, I am left with a hole in my hood once again. Do I buy a shaker or do I put on say a cowl, or an L88 or something else. What would look cool.
A. Original shaker, can it be mated with a chevy 350 and edelbrock performer?
I've got a black air cleaner that appears to be the original.
B. L88 4 or 6"
L88 and Cowl, I'd get to use my super cool tall chrome air cleaner
C. Cowl 4 or 6"
Also I like to make little electronic doors for the shaker if I do get one. Like a switch inside. Like one of those red air force ones, with a warning light or something. It'd be really gimmicky and cool.
Old 02-17-2007, 06:21 AM
shaker
I had a 79 TA that I put a dual quad 455" Olds in, and I used ELEVATOR bolts and body panel like glue to glue the bolts to underside of hood, and installed original hood scoop, as the 455" is a taller block and the SHAKER would not work. The glue used was NOT regular EXPENSIVE made for body shops panel glue, but was a 2 part epoxy that I bought at the hardware store, and it worked VERY well.. but you must remove the paint and clean METAL well before gluing, and rough up the face of the bolts. also I used 1/4 inch rubber insulators between the hood and scoop, and opened the back of hood scoop for fresh air. Cheep and easy.
Old 02-17-2007, 06:56 AM
To be honest with you, if you attached the shaker that way and you're planning to fix the damage like that, I can imagine what you'd do in molding a cowl onto the hood. Ever think of having a professional work on it?
Old 02-17-2007, 07:34 AM
leldai73's Avatar
Its just metal,you're the boss
shake it up. im no trans am expert but im sure with a little ingenuity you can hook all the parts together and have it look nice. thats what hot rodding is about, not buying and installing kits you know will work or else you just send them back. take your time do it right and not only will it look cool but you'll have this overwhelming sense of accomplishment after wards. i like to call it the holy crap i did it feeling.
Old 02-17-2007, 08:30 AM
Shaker
My car was 403-powered originally, so to make the shaker work on a Pontiac I had to redrill different holes in the metal shaker base (the flat part that sits on the air filter housing). Shakers came on Chevy engines, too, so you can make yours work as well. I cut out the shaker opening to let fresh air in and don't worry about any flapper. If I lived where the climate was really cold and icy I'd just cover the opening with some kind of fitted scoop cover. Sounds like you're going to learn by making mistakes, so use a little forethought and carry on. You can always buy another metal or 'glass hood if you goof so don't be paralyzed with fear. We've all been there.
Old 02-17-2007, 09:51 AM
Ahhhhhhhh Shaker hood Scoop....... (in my best Homer Simpson or Bevus voice take your pick) I would do ANYTHING to make the shaker hood scoop work. In my opinion, they WERE what made it a Trans Am.
Old 02-17-2007, 11:22 AM
cab cab is offline
MartinSR is right - if you don't put the shaker on you might as well leave the Bird decal off too, neuter it, and call it a C-A-M-A-R-O. In the second gen cars the TA's were so much more desirable than their Camaro counterparts, especially in the 74-81 years (IMO). WS6 handling packages, SD motors in 73/74, 400 cube Pontiac motors...Of course soem might call me biased...since I have owned 3 Birds in my lifetime (although oddly enough never a 2nd gen - had an 82, a 95, and now a 67...guess I'm due for a second gen!)
Old 02-17-2007, 04:42 PM
Gladis's Avatar
okay, so I am going to make the shaker work. It's TA and it should have a shaker. Cowl's are for Camaros and L88's for corvettes. The flapper thing for the shaker is just too cool not to do also.
http://www.netn2it.com/10th-ta/scoop.htm
of course I'm going to do it myself too, local hobby shop should have what I need to do it. I'll also have the holy crap feeling, which is priceless.
Old 02-17-2007, 06:22 PM
I just went through the same thing on a 79 Transam, the aftermarket alluminum intake and holley 750 on the 403 really screwed up the fit of the original shaker hood scoop. I looked at modifying the aircleaner assembly and scoop to get the right height but in the end I modified the upper portion of the scoop to bolt to the bottom side of the hood. I made some sheetmetal strips to fit the contour of the perimeter of the scoop opening, installed studs and glued the strips to the bottomside of the hood with panel adhesive. The scoop assembly got sectioned and drilled and bolted up from the bottomside. It looks just fine but the shake sure is missing. It did stiffen up the flimsey hood though and provide plenty of clearance. Also make a drain for the trough area of the scoop and use a gasket between the scoop and the hood so the paint doesn't wear off the sheetmetal edge and dig into the scoop-closed cell universal weatherstriping works fine.
Old 02-18-2007, 10:50 PM
BIGSKY's Avatar
See project in Photo Album
Originally Posted by cab
WS6 handling packages...
Ah, I think the WS6 option made that car great. I had a 72 Z28 just after high school, and the car ran hard, but my buddy's 79 TA killed my car in the corners and was way more fun to drive. I have had a soft spot for the 79 TA since.
79 trans am rear gearing Rough-Rider Transmission - Rearend 3 02-05-2007 08:12 PM
79 trans am rear gearing Rough-Rider Transmission - Rearend 4 01-23-2007 08:16 PM
Me and my 79' Trans Am steel dragon Introduce Yourself 1 01-21-2007 04:28 PM
AOD into mustang Stangman196700 Transmission - Rearend 3 12-16-2004 08:51 PM
First time trans rebuilder...need tips! 4 Jaw Chuck Transmission - Rearend 14 06-23-2004 02:29 PM
