79 Trans Am Shaker Hood Scoop fit issue - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-05-2007, 10:45 PM
Gladis's Avatar
The shaker scoop sits too far back on my chevy 350 to fit with the hole in the hood. Anyone know any ways to fix this problem? I think i am out of luck. It also seem to be a little high.
Old 03-06-2007, 12:21 AM
Is the base from a 400 or 403? If so, you will need a SBC base AND scoop from a 81 trans am. Not very many made either. I believe there is a guy making some aftermarket bases for SBC also.
Old 03-06-2007, 07:38 AM
One I have NO idea how the bases look but cant you just offset the opening in the base? It would take some cutting a welding. Cut out the carb opening and shift the base around til it fits right then weld it back up...Eric
Old 03-07-2007, 07:25 PM
I've got a base for a chevy v8 and a 403 olds and they are quite a bit different, the chevy base is a lot smaller too. I dont know if you could modify it, I mean I guess you could. Just about anything's possible.
454 chevy in 79 trans am, possible? Trans Am Benny Engine 9 12-31-2011 11:06 AM
79 Trans Am Hood Cable problem Gladis Body - Exterior 6 01-12-2007 01:58 PM
hood scoop install ? jim.. Body - Exterior 11 02-13-2006 10:02 AM
Removing fenders? Jag Daddy Body - Exterior 3 11-26-2003 04:42 AM
body panel alignment gmonkey Body - Exterior 5 09-01-2003 06:50 PM
