79 Trans am steering knuckle..tight! - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-17-2011, 12:39 PM
Hi, I am in the middle of rebuilding my TA's front suspension. I just installed the spring and steering knuckle and tightened the knuckle to specs(65lbs up /85lbs low. It seems really tight..like it would be an issue if I attempted to drive it. Before I do the other side I am looking for any info on this. I have greased the new fittings on the new upper/lower ball joints. THANKS!
Jim K.
Old 01-13-2012, 01:12 PM
T-bucket23's Avatar
Wiki Edits: 26
Jim K.
Maybe one of the ball joints got damaged. It should turn fairly free and smoothly. If you cant turn it easily it almost has to be ball joints as that it what it turns on. Keep in mind that new ball joints are going to be stiff.
Chet
new steering gearbox is too tight ! knighthawk Suspension - Brakes - Steering 8 06-12-2011 10:35 AM
Steering knuckle hits header!! APalusky Suspension - Brakes - Steering 39 11-27-2010 10:32 AM
question about steering knuckle when replacing brake pads pigjamelectric Suspension - Brakes - Steering 1 09-14-2008 02:03 PM
'42 Dodge (?) steering knuckle woes Gearhead forever Suspension - Brakes - Steering 8 02-13-2005 09:11 PM
steering "knuckle" bolt on bowtiedragracing Suspension - Brakes - Steering 1 09-20-2003 12:32 PM
