'79 Trans Am subframe to a '56 Chevy Pickup? - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-22-2009, 07:53 PM
Hello
Has anyone had experience and/or info for using a '79 Trans AM subframe on a '56 Chevy pickup. I understand that the earlier Firebird and Camaro were virtually identical. But does this hold true for the later models, like the '79? Have not bought subframe yet. I wanted to see if I was in for a hassle, or if it would be like the later model Camaro too. I would appreciate any advice.
thank you
Old 02-22-2009, 08:08 PM
NEW INTERIORS's Avatar
Set no limit's on yourself
Originally Posted by gary47speed
Hello
thank you
I did several last year.I did a 58 Chevy with a Nova with the rear steer.It worked out great.I use a lot of the 79 - 80 camaro's,The Nova is about 1.5'' narrower then the Camaro hub to hub.Here's a picture of the 58 Chevy truck,And my 57 Chevy car I did.
ID:	36474   Click image for larger version
ID:	36475   Click image for larger version
Old 02-22-2009, 08:32 PM
'79 trans am subframe to '56 chevy p/u
Thank you for your response. So, you see no problem with the '79 Trans Am subframe, just like doing the Camaro? Your frame work looks great! Thank you!
Old 02-22-2009, 09:36 PM
It just put's the wheels out alittle.Like I said,the Nova is even better.If it was me,I would try to go with the Nova.. And the Monte Carlo Is even narrower then the Nova.
Old 02-23-2009, 07:10 AM
'79 Trans am subframe to '56 chevy p/u
I appreciate your feedback...
from the looks of your frames you have perfected the procedure. I will check and see if my source has a Nova or a Monte Carlo rather than the Trans Am I know he has some Camaros. He is honest, close, reasonably priced and will deliver no extra charge. That was part of the motive of going with the Trans Am. But if it is going to be a disadvantage then I should rethink this.
Thank you and regards
Old 02-23-2009, 08:41 PM
Last journal entry: 1955 Chevy Truck
I am in the middle of a Monte Carlo clip, and it has worked out great. The best thing about the Monte G-body clip is that you have plenty of room to lower the front end, and still have all of the steering radius without rubbing the fender lips. The Monte track width is 58" and works great under the truck, especially if you want the front end lowered. I welded the front end up at ride height without dropped spindles, so I still have the factory ride without the expense of dropped spindles and too wide of track. I got alot of help with another guy on the forum that is doing the same thing. You can read our posts titled "55-59 truck with G-body Clip" on the same forum category. Good luck on your choice.
http://www.my.opera.com/Oleblue55/albums/
ID:	36520   Click image for larger version
Old 02-23-2009, 10:32 PM
Hello
Thanks for your info, sounds like the G-body is the best choice. I really like the look of your truck, gonna be sweet when you get it done, nice stance.
I appreciate your help, it helps to get feedback from experience.
Regards
Old 02-24-2009, 06:58 AM
It has worked out well for me. I guess it's just what you have available and the finished ride height you want. The G-body stuff around here is alot less expensive and by far more available than the F-body and Nova clips. I just didn't want to spend alot on custom wheel offsets for the front. The narrower track allows the front suspension and turning radius full travel without any issues. Good luck in whatever you decide to do. This is my first truck project, and I am really enjoying it.
Old 02-24-2009, 07:15 AM
Hello-
I appreciate your input. I feel that the best direction is the narrower set-up, but I am still faced with a cost of unit and delivery cost issue.
First the cost of this Trans Am suspension is very cheap, plus I live in a rural area and delivery is free. But, I realize that it's "like pay me now, or pay me later" kind of deals. Less expense initially, more later, for wheels and some sacrifice on wheel travel. I am checking around locally to see if I can find a more desirable suspension at a competitive price.
I guess the ball is in my court now. Thank you very much for your advice.
Regards
the history of chevy v8's savman1 Hotrodders' Lounge 43 03-02-2012 06:57 PM
62 chevy pickup with 327... automatic or manual trans? harley83 Transmission - Rearend 17 02-05-2009 02:27 PM
Which Coilovers to get? 56 pickup camaro subframe TK56 Suspension - Brakes - Steering 5 01-06-2009 10:38 PM
LS1 Radiator in 56 Chevy snimmo Engine 8 10-22-2005 05:44 PM
56 chevy rear disc brakes 56-210 Suspension - Brakes - Steering 4 10-08-2003 08:13 PM
