79 z28 reverse lights come on in neutral - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-04-2013, 07:16 PM
When I put my 79 tranny in reverse I get no lights, when I move it to neutral the reverse lights come on. If I move it gently back towards reverse it will sometimes stay on. I figure I need to adjust something but I'm not sure if it's the actual linkage under the car or if there is some thing else. Any help (and pictures of which to adjust) would be appreciated. Oh yeah, it's a automatic floor mounted. Thanks
Old 04-04-2013, 08:28 PM
gonzo08383's Avatar
Last journal entry: brakes
should be a limit switch in the shifter assembly. probably just needs adjustment. pull the shifter cover off and take a look see. should be a tab that engages the switch just look in there it should be somewhat apparent. its real easy if you have a b&m shifter. not overly familiar with the stock shifter. should be relatively close tho.
The Following User Says Thank You to gonzo08383 For This Useful Post:
Benscamaro (04-06-2013)
Old 04-04-2013, 09:01 PM
66GMC's Avatar
Get in, sit down, hang on
Last journal entry: Cab Removal
NAPA Echlin #NS6589 Back-up / Neutral Safety Switch.
This one looks like it's column-mounted, but I would think that there must something similar mounted to the gearshift lever inside the console?
Sounds like it's just out of adjustment ... does it crank properly or do you have to fiddle with gearshift as well?
Some N/S switches used to have an alignment hole that you inserted a paper clip into while in the PARK position to hold it in the desired spot while you tightened the screws to the column?
Not sure on that either, though ...
Edit:
Read This
Park/Neutral Safety Switch acts as the reverse light switch and is located down on the column for both column and console applications (GM just didn't change the column/console design and used a backdrive rod from the transmission to turn the column shift lever and vice versa...).
The Following User Says Thank You to 66GMC For This Useful Post:
Old 04-06-2013, 09:24 AM
Reverse light
Thank guys. It does crank fine and I have no problems with the ignition lock. I'll do some poking around to see if I can adjust it.
4l60 no reverse/forward on neutral matador23uti Transmission - Rearend 2 03-12-2011 10:33 AM
4l60e no reverse first on neutral matador23uti Introduce Yourself 2 03-11-2011 06:50 AM
95 Z28 fogg lights RetiredRodder Electrical 1 03-05-2011 01:34 PM
wants to go in reverse when in neutral mainejohn Transmission - Rearend 6 02-27-2011 05:15 PM
neutral safety/backup lights 67stepsidebeast Electrical 10 10-13-2005 09:14 AM
