-   -   '79 Z28 - Super T10 Chatter and problem ...Video inside (http://www.hotrodders.com/forum/79-z28-super-t10-chatter-problem-video-inside-222692.html)
Calderone 08-08-2012 07:19 PM
Guys not sure if you remember this but we have been following my friend's problem for a year or so now , this is a 1979 Z28 with a BW Super T10.-
To this day is the only problem this car has , and this is what happening :
On take off , any gear there is a chatter and a loud sound, the car shakes but once that is rolling it goes away.-
Here's a video from last year :
We already replaced (trying to alienate the problem) :
- New Harmonic Balancer
- New Flywheel
- New Pressure plate and Disc
- New T-Bearing
Once the car is rolling , there is no problem at all
Today we found out that the noise comes from the transmission tail and there is a huge play there when i move the wheel.-
New video
U Joints seems fine , if i move from the transmission joke , the play is there
in the tran so i assume something is wrong with the transmission.-
What could be causing this ?
Something left out ?
Thanks !!!
RWENUTS 08-09-2012 07:25 AM
My first thought was the front yoke on the drive shaft not being deep enough into the tranny. I've always set them up by pushing it in and pulling it out 3/4 inch. Looks like yours is out 3 times that.
AutoGear 08-09-2012 10:18 AM
Before I scrolled all the way down; I was going to say theres either a problem with the splines on the output, or the yoke; OR the yoke isn't fully engaging.
vinniekq2 08-09-2012 11:39 AM
I had a front drive shaft on my 4x4 make that sound. The yoke was worn out and skipped
Calderone 08-09-2012 11:34 PM
thanks guys
