We're winning the case!
Hotrodders Bulletin Board > Tech Help > Engine
  #1
Old 06-12-2005, 12:21 PM
Mustangsaly's Avatar
Mustangsaly Mustangsaly is offline
7qt Oil Pan & Pickup SBC Small Block Chevy
can someone tell me the advantages of a 7qt Oil Pan ? (I Think Theres Something about keeping your Oil Cooler) this one has the Pickup included, would this be suitable for street use ? would you need a HV Oil Pump with this, i'm kinda wanting one for a 71 Chevy P/U.
http://cgi.ebay.com/ebaymotors/ws/e...7978632325&rd=1
Mustangsaly
Old 06-12-2005, 04:32 PM
DoubleVision's Avatar
DoubleVision DoubleVision is offline
2nd Gunman On The Grassy Knoll
I don`t think a 7 quart pan is needed on the street, that`s a bit of overkill.
I would just use one of hamburgers new pans, a diamond stripper windage tray and let it run at that.
Old 06-12-2005, 06:00 PM
whats one of hamburgers new pans, a diamond stripper windage tray ? where can i see one? would that one i posted work one the street with The sump having a hinged trap door to keep the oil where it belongs under heavy breaking & acceleration ? would you need a HV Oil Pump ?
Mustangsaly
Old 06-12-2005, 06:02 PM
GoneNova/406's Avatar
GoneNova/406 GoneNova/406 is offline
i bought mine for the reason you mentioned,overheating.more oil volume will help to keep your oil cool and anything to keep your block cooler in that situation helps.i think i had some distortion in one of my cylinder cause i could not fix the prolem with out going to extremes.i also used a dual remotr oil filter with qt. filters and an oil cooler among other things.i did finally get it under controll.i had spent to much money to turn back.usually just the goody's in a good 5 or 6 qt. pan is sufficiant.i'd rather use a z/28 oil pump than a h.v. pump.a stock pump with the 65-70 psi spring or a big block pump will work also.i use the big block 65 psi pump and spring (m77) from jegs 21.00.
Old 06-12-2005, 06:06 PM
poncho62's Avatar
poncho62 poncho62 is online now
poncho62's barnstar
Wiki editor
Wiki Edits: 5
Heat is part of the reason......also, high revving engines can possibly run out of oil. It all gets pumped to the top and doesn't get back down to the bottom pickup quick enough. More oil in the pan can prevent this.
Personally, I don't think you need a 7 qt pan....maybe 5.
Old 06-12-2005, 07:32 PM
edge's Avatar
edge edge is offline
Time is short, are you ready?
Looks like a Moroso pan with a Milodon pickup. The Moroso pan is actually 8 1/4" deep. You need to be careful with buying the pickup. While I am sure that style will work with that pan, the length is different between a standard oil pump pickup and one used on a high volume pump. Not enough information to make an informed decision. Like others said, no need for 7 quarts on the street, and the HV pump is overkill. Ed www.edgesz28.com
Old 06-12-2005, 07:52 PM
killerformula's Avatar
killerformula killerformula is offline
killerformula's barnstar
Wiki editor
Last wiki edit: Carburetor
Wiki Edits: 3
I wanted a nice new pan for my ride and bought a milodon setup. Its a 7qt unit, maybe a bit overkill, but was a good design and didn't cost much more than a normal one for 2 qts of insurance!
K
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Similar Threads for: "7qt Oil Pan & Pickup SBC Small Block Chevy"
Big Block vs Small Block Chevy bigjoedo Engine 63 10-15-2008 04:42 PM
the history of chevy v8's savman1 Engine 30 01-25-2008 01:02 PM
Building A 302 Chevy Scorpio Shaping Flow Hotrodding Basics 6 01-16-2007 05:55 AM
Oil pressure loss SB Chevy Finmike Engine 30 06-12-2004 10:27 AM
questions on building a small block chevy ATMRacerTX Engine 4 11-20-2003 02:32 PM
