Thread Tools Search this Thread share on Facebook
  #1
Old 01-17-2009, 04:41 PM
redneck_9018 redneck_9018 is offline
8.1 chevy big block need some help befor i buy!
OK so im thinking about buying a 2002 Chevy 8.1L everything is complete but there isn't an intake manifold put a older carb intake on it? thanks
Register now (free) or login to remove ads
Old 01-17-2009, 04:47 PM
BOBCRMAN@aol.com BOBCRMAN@aol.com is offline
The heads are unique to this motor. The aftermkt has no carb intakes for it. Or heads for that matter.
These engines also use an oddball crank rod balancer flywheel and piston setup. Not your daddy's Big Block!!
Old 01-17-2009, 05:04 PM
re
ok now thats out of the question, would it bolt up to an older th350
Old 01-19-2009, 10:05 PM
stlouischevyman stlouischevyman is offline
arnt they just a stroked 454? I thought the block was the same.
Old 01-19-2009, 10:16 PM
re
ya the just increased the stroke, but they changed the heads and accessories mounts
Back to top
Search this Thread:
Advanced Search
vB code is On
Similar Threads for: "8.1 chevy big block need some help befor i buy!"
ThreadThread StarterForumRepliesLast Post
big block or small block chevy69YENKONOVAEngine8105-13-2010 07:26 AM
Big block water pump on small block!TVR383Engine1404-15-2008 07:43 AM
Big Block Chevy ... How much does a block weighRob KellerHotrodders' Lounge503-24-2008 06:10 PM
Big Block Chevy Pushrod lengthChoctaw BobEngine1304-16-2006 11:54 AM
Swapping to big block chevylow77rideEngine509-15-2004 09:30 PM
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.6.0
