8.2 10 BOLT upgrades or swap - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-24-2004, 12:37 PM
Sleeve396's Avatar
Allright gang I am building up a car for my son (68 chevelle) that has the original 8.2 10 bolt non posi rear, I have already dropped in my old 396 and a saginaw 4 spd with a wide ratio and a low first gear, I have not found a 12 bolt yet so I am stuck with this for now. I am pricing an auburn traction lock rear with 3.42 gears for it but wonder if will hold up. Has anyone built up a early 10 bolt? It will take about 650.00 for parts and gears my only other viable option would be a later model 8.5 rear from a malibu or montecarlo which probably would be better suited to upgrades as the gears are more available and also posi units are cheaper, I believe that the later models 73 and up have the same 4 link mountings but might be wider any ideas out there! yes I am still looking for a 12 bolt btw
Old 04-25-2004, 09:59 PM
Somebody at Southside Machine told me the 73-77 had something different about the mounting on the rear end.
Old 04-26-2004, 07:32 AM
M&M CUSTOM's Avatar
Wiki Edits: 9
I don't know about the older housings, but the 73-77's are about 1-1/2 inches at the lower mounting bars than the 78-87's.
I would say any of the major suspension upgrade manufacturers would have the answer. Otherwise, a trip to a junkyard and some accurate measuring can answer this.
If this post can get someone to come out with accurate measurements I will post the findings in my Axle information sticky post at the top of this forum.
Old 04-27-2004, 07:46 AM
Sleeve396's Avatar
It seems that you are correct on the 73-77 rears measuring wider from end to end. Since that would limit tire and rim selection if I were to try to install into a 68 chevelle I am stuck for now beefing up the original 8.2 10 bolt, Are there any vendors who still have a posi case available ? I would probably run a 3.36 to 3.73 ratio.
Old 12-01-2005, 11:41 PM
73 rear
The shock mounts will need to be welded on the back side of the rearend as 73s went to shocks in front of the rear!
Old 12-02-2005, 12:07 AM
I haven't had any problems with mine yet........if it's possible for a kid to treat it nicely, it might not break. Might want some of those c clip eliminators put in just in case and/or one of those spiffy rear covers with the 2 bolts in the center. I haven't priced this all out yet, maybe it would be cheaper to find a 12 bolt.
68
Old 12-02-2005, 08:32 AM
1969NovaSS's Avatar
turbo lag......yeeeeehaaaaaaw
8.2 strength
I asked a question like this and they told me the weakest part was the spider gears. If you run a powertraxx it eliminates the spider gears. also c-clip eliminators wouldnt hurt either.
Old 12-02-2005, 10:37 AM
bigbadbowtie's Avatar
Bottle Fed
what about an 8.5 10 bolt out of a GN....
Old 12-02-2005, 11:05 AM
fearsomefairmont's Avatar
Good idea....
If you run an 8.5 10-bolt from an Olds, they are a decently strong rear-end. My '72 Olds A-body has one, and they also have the added benefit of positive axle retention and do not need c-clip eliminators. They are a good compromise before finding a spendy 12-bolt.
The one in my '72 has held up fine under the strain of a 350+hp/500 ft/lbs 455/Turbo 400, including plenty of burnouts. It is even an open diff and it hasn't broken. The stock posi units are alright too, if you can find one....
The GN 10 bolt is your best bet, though, although I am not really sure about fitment.
Cheers,
Andy
Old 12-02-2005, 01:42 PM
Bottle Fed
Im not sure about the GN rear fitting either. The 8.5 gm 10 bolt is quite strong. I ran mine with stock axles to low 11 sec passes in a 3450 lb car.
On the other hand I broke an 8.2 10 bolt in my 67 camaro with a mild 355 and 4 speed. Chewed teeth off the ring gear.
Old 12-03-2005, 11:22 PM
xntrik's Avatar
Save a horse, Ride a Cowboy.
Yes but a Powertrax still drives the locker gears with the carrier cross pin, and the pin still breaks the carrier itself.
Also the thing that ruins the stock diff is the shock loading when the power hits. Auto trans usually take up all the gear lash before the power hits, so the diff last longer with the auto trans. Careful use will have it last with a stick shift.
Old 12-04-2005, 04:32 PM
67 Deuce 4 Me's Avatar
Bowtie or Die!
My Nova is a 8.2 Ive been running over 400 hp on it for a while, it has a fatory posi unit in it. It still lives on, no breaks or noises.
Old 12-06-2005, 10:37 PM
8.2 10 bolt
If you are simply building a car for your kid and is not going to see a lot of track time the 8.2 will be plenty strong enough for about 400 horse power. I would definately upgrade to the posi but stay away from the Auburn Gear because it is not rebuildable and the Powertrax unit will bang, clunk, click, and make all kinds of noise. As well it is probably not the best type of locker to put in the diff for a younger guy with a lot of horsepower. 12 bolts are available but costly at approximately $2500.00. Go 3.42 to 3.73 gears so it is streetable but will still have low end torque.
Old 09-20-2007, 04:47 PM
12 bolt
look in the buick skylarks 1968 or 1969 my brother has a custom it came with 12 bolt rear
