8.2" or 8.5" 10 Bolt? - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-24-2007, 03:52 PM
71 Ventura's Avatar
I know that I have a ten bolt rearend on my car, but I don't know if it is an 8.2 or an 8.5 inch. Does anyone know how to identify which it is?
Old 10-24-2007, 04:22 PM
What year and model? If not original, check pinion nut size. 1.25" is 8.5. 8.2 is smaller, I think 1.062".
Old 10-25-2007, 10:02 PM
71 Ventura's Avatar
It is the original rear end. It is in a 71 Pontiac Ventura II, which is the same thing as a nova, but Pontiac. It came from the factory with a 307 V8 and a Turbo 350 trans.
Old 10-30-2007, 07:22 AM
http://novaresource.org/axle.htm Check this sight out I know that alot if not al of the nova stuff is the same so this might be of some help.
Old 10-30-2007, 02:55 PM
John Chapman's Avatar
1965 Buick Skylark
http://www.pontiacventura.com/index.html
Might be some help there. Check the links. Don't automatically expect the Nova rear end to be the same, as BOP frequently specified different running gear.
Cheers,
JMC
Old 10-30-2007, 06:20 PM
F-BIRD'88's Avatar
Yada Yada Yada
differential cover pictures to ID your axle type PDF
Old 10-30-2007, 06:29 PM
most 8.2 rear ends had the C cuts on both sides of the cover . By 72 all had 8.5 or a 12bolt . But I did see 1971 GMs with 8.5 rear ends . The 8.2 also has bolted in axles . The 8.5 uses C clips .
Old 10-31-2007, 03:04 PM
71 Ventura's Avatar
Thanks for the help guys. I am pretty confident that it is an 8.5 from all the little specs and pictures.
Old 10-31-2007, 04:47 PM
curtis73's Avatar
Hates: Liver. Loves: Diesel
Last journal entry: 1999-2001: Getting it on the road
Wiki Edits: 16
Did the 8.5 exist in BOPs in 71?
Keep in mind that in 71-76 chevys there was an 8.75" 12-bolt with only 10-bolts on the cover, and in earlier cars there was a 10-bolt with 12 on the cover. The true count is the number of bolts on the ring gear, just make sure its not one of those oddballs. I had an 8.75 in a 73 station wagon and parts were difficult to find.
Chevy 350 Crankshaft bolt removal 75gmck25 Engine 11 03-14-2008 06:27 AM
Can rear end gears be swapped at home? (8.5" 10 bolt) Warrant Transmission - Rearend 6 09-22-2006 09:55 AM
body parts fitting anyoldchevy Body - Exterior 10 02-20-2005 09:20 AM
F-body differentials, 9 bolt Borg Warner vs. GM 10 bolt Mad Maggot Transmission - Rearend 8 02-17-2005 08:02 PM
10 bolt to 12 bolt 1980Impala Transmission - Rearend 8 04-25-2004 04:48 PM
