8.2 pontiac rear end. - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-23-2009, 04:52 PM
i have an 8.2 inch pontiac rear axle housing and i am looking for a posi trac carrier. i have heard that 8.2 bop carrier will work. i found an "o" type 10 bolt oldsmobile carrier and i was wondering if it will fit my housing?
http://cgi.ebay.com/ebaymotors/Oldsm...1%7C240%3A1318
Old 04-24-2009, 03:05 PM
SSedan64's Avatar
Not sure about the 31 spline axles. Look at the fine print at bottom of 1st chart.
Some Info here.> http://www.oldsmobility.com/10bolt-tech.htm
Old 04-24-2009, 06:14 PM
ericnova72's Avatar
More for Less Racer
The type O axle is a lot different than the 8.2 BOP axle, what you are looking at won't work in the 8.2 BOP, it will only fit the type O axle.
4x4 12 bolt rear end same as 2wd rear end??? Ed ke6bnl Transmission - Rearend 2 05-24-2008 02:25 PM
Narrowing a 9" ford rear end powerrodsmike Suspension - Brakes - Steering 6 05-05-2007 12:53 PM
S-10/Camaro Rear End slaveforthewave Transmission - Rearend 7 02-20-2006 01:44 PM
Important rear end mounting question 71gtx Transmission - Rearend 2 01-04-2004 06:05 PM
8.2 ,8.5 OR 8.8 REAR END dill Transmission - Rearend 0 01-10-2003 04:53 PM
