8.2 rear end - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-29-2012, 08:24 AM
8.2 rear end
i hv pulled 1.69 60 ft times 3600lbs car i hv moser 28 spl axles rich mond gears girdle cover auburn diff how much quicker before something gives lol ?
Old 04-29-2012, 10:26 AM
LATECH's Avatar
I dont know, but my sled has the same diff. This is a thread i will follow as it progresses.
I have read that the 8.2 is a weak rear, i am guessing the carriers break and that the 28 spline axles are pretty weak too.
I am sure there is truth too it, no doubt. There are upgrade gears, such as carriers that have limited slip cones or clutches in them depending on brand/design.Also 31 spline axles IIRC.
Eaton , and others like yukon gear sell everything you could want.I have heard that it isnt a good investment due to the 8.2 weak spots.
Like I said I would like to hear more also. We have a member named "Big Gearhead" who had tons of experience with this exact thing, but havent seen him here for a bit.
Look around at www.ringandpinion.com
Fact is stranger than Fiction
1953 Buick Special-front end rear end?? mbjeep Suspension - Brakes - Steering 8 12-06-2009 07:32 PM
stock 63 chevyII rear end vs. s-10 rear end david6chevy Transmission - Rearend 3 08-17-2009 05:36 AM
Gm 12 bolt truck rear end vs. car rear end '54 Pontiac Transmission - Rearend 6 02-05-2009 06:17 PM
4x4 12 bolt rear end same as 2wd rear end??? Ed ke6bnl Transmission - Rearend 2 05-24-2008 03:25 PM
Ford 9" rear end vs stock 89 chevy truck rear end jimmy p Transmission - Rearend 2 12-07-2005 04:28 AM
