8.2 rearend housing or not? - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-11-2009, 06:11 PM
I have got an 8.2 rearend housing that i beleave is an 8.2 b or p housing. Problem is that it has a 12 bolt carrier in it can anybody help to solve problem. Would like to know what type of parts to put in it.
Old 04-11-2009, 07:59 PM
Eaton sells a posi differential for an 8.2 ring gear through Summit for about 600.00. Be sure to check axle spline count as well before ordering. Moser sells 28 spline axles for that differential. I ran a 10 bolt 8.2 rear with 3.73 gear with no problems on a mid 12 second track car.
Hope I could help a little.
Glenn
Old 04-12-2009, 11:28 AM
Sounds like you have a type O rear end. Used in Oldsmobiles in the late 60s. National Drivetrain has a limited number of ratios, and hard parts for them.
Old 04-14-2009, 08:55 PM
fast68's Avatar
likes chevy trucks & boobies
