8 3/4 rear end - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-27-2006, 02:34 PM
8 3/4 rear end
Can someone please help me find a Mopar 8 3/4, sure grip(posi) rear end to fit a 1972 Dodge Dart Swinger. The car currently has a 7 1/4 rear. Any help would be greatly appreciated.
Old 01-27-2006, 06:29 PM
onebadmerc's Avatar
I need a bucket of arc sparks
That will be a difficult order to fill, if you find a Dart 8 3/4" it will probably cost a arm and a leg. I am facing the exact same problem you are having. I also have a 72 Dart that is in need of a replacement rearend, the crappy 7 1/4" is junk and the best I can find is a 8 1/4" for $80. A Dart 8 3/4" rearend would be great but the last one I saw for sale on Ebay was $800 and it was a open dif.
Old 01-27-2006, 07:27 PM
69coronet's Avatar
You might look through the classifieds over at moparts.
http://board.moparts.org/ubbthreads/...=0&Board=Trans
Theres a member there (doctordiff) that is a rear end guru/builder/ I just bought a new 3.91 geared 8.75 center section from him, not sure if he handles full rear ends but it wouldn't hurt to ask.
Richard
Thump Thump in rear end?? HotRodMan Suspension - Brakes - Steering 7 01-24-2007 06:09 PM
8 1/4 to 8 3/4 rear end Leaf Spring Problem... 71gtx Transmission - Rearend 21 04-19-2004 07:17 AM
Rear End Change black66 Transmission - Rearend 4 01-28-2004 09:21 AM
Important rear end mounting question 71gtx Transmission - Rearend 2 01-04-2004 06:05 PM
Ford 7.5" Rear End Traction-Loc Install nightrain_rod Transmission - Rearend 2 12-30-2003 06:38 PM
