8.5 0r 8.2 posi - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-24-2004, 02:48 PM
interceptor429's Avatar
New Member
8.5 0r 8.2 posi
could someone tell me how to tell the difference between the 8.5 and the 8.2 the posi unit is out of the differential and the guy doesnt know which it came from ,any help on how to i.d. it would be great,thanks interceptor,keith
Old 05-24-2004, 07:21 PM
M&M CUSTOM's Avatar
Wiki Edits: 9
Are there any casting numbers on it?
Is the ring gear still bolted to it?
Both have a ring gear to carrier bolt count of 10.
Are the splines in the carrier able to be seen, if so then-
The 8.5 would have a spline count of 28, and the 8.2 would have 25.
The 8.2 above would be a 64-72 "Chevy" and the 8.5 would be a early 70's in the range of 70/71/72 or later.
Is the pinion gear available?
And last but certainly not least is the axle housing still able to be found?
Old 05-25-2004, 01:23 AM
The Chevy 8.5" 28-spline posi carrier comes in 2 versions. The 2-series, used with 2.56 & lower ratios, has a casting number ending in -409. The 3-series, used with ratios from 2.73 up, has a casting number ending in -408.
Old 05-25-2004, 04:34 PM
Ghetto Jet's Avatar
current hot rod: CTS-V
Last journal entry: Lets Get Started With the Improvements
the 8.5's have strong 1.625" diameter pinions with 30 splines (like the GM 12bolts), while the 8.2 (chevy not the 8.2 BOP used) only have 1.438" pinions with 25 splines.
Old 05-27-2004, 01:30 PM
I just saw on another board that the 8.5's have 7/16" ring gear bolts, while 8.2's have 3/8".
