8.5:1 vs. 10:1 how much will this help - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-05-2002, 09:53 PM
Post 8.5:1 vs. 10:1 how much will this help
I know its probaly a diificult question to answer but i have a 79 350 with 8.5 to 1 compression if it had 10 to1 compession what would be the power diiference?
Is there a formula?
thanks
Old 11-06-2002, 02:05 AM
Post
Theoretically you chould see an increase of 20 horsepower and 26 ft,lb. of torque.
As long as your engine is up to running this compression ratio.
I use more that a straight math formula, I run the car spec through a program called PC HOTROD.
Old 11-06-2002, 03:03 AM
woodz428's Avatar
Troll Hunter
Post
An older engineering book stated that for every point of compression you increased up to 11:1 (for gasoline)you achieved about a 6-10 percent increase. After that it falls to about 1-2 percent.
Old 11-06-2002, 04:46 AM
TurboS10's Avatar
Last wiki edit: Auto Terms and Definitions Used in Modern Engine T... Last photo:
Wiki Edits: 2
Post
Agree with the previous, but one thing that it really also helps is the low end response. This makes it feel like more power than it might actually make.
Chris
