8.5 10 bolt spider gears - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-02-2008, 04:40 PM
Hi guys, Ive come across this forum several times while searching for stuff and you seem to be a wealth of knowledge so I decided to join cause I have a question. I just bought a 79 camaro and it has 2.41 rear end gears in it, but I have the original 3.08s in a box. I understand the carriers are different for 2.73 down and 2.73 up. The 3.08s are bolted to the original carrier, but the spider gears and side gears have seen better days. so my question is, are the spider/side gears the same in both carriers so that I can take the ones in the 2.41 carrier out and put them in the 3.08 carrier? thanks
Old 07-02-2008, 05:38 PM
SSedan64's Avatar
Yes they should swap with no problem.
8.2 or 8.5 10 bolt? yragat Transmission - Rearend 2 10-17-2007 09:30 AM
Can rear end gears be swapped at home? (8.5" 10 bolt) Warrant Transmission - Rearend 6 09-22-2006 10:55 AM
Vibration 8.5 10 bolt. need some help. red_rider52 Transmission - Rearend 10 08-29-2006 02:45 PM
8.5 10 Bolt Chevy Info Needed jsteve068 Transmission - Rearend 6 09-26-2005 05:09 PM
strength of 8.2 inch 10 bolt rearend??? 70chevelle327 Transmission - Rearend 4 02-11-2004 11:07 PM
