Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 8.5 10bolt question
Old 10-03-2011, 04:44 AM
SSedan64's Avatar
SSedan64 SSedan64 is offline
Originally Posted by CHUMPCHANGEBU
are all the 8.5 10 bolt rear ends the same? i found one for a 9c1 cop car but i know he bolt pattern is 5x5,can i switch axles to 5x4.75? can they also be shortened to work in a 1978 chevy malibu? has anyone ever done this before?
moe
The stock 78-88 G-body Rear width is:
58" Drum to Drum.
52.125" Housing Flange to Flange.
If your 9c1 Rear uses 28-Spline axles, you could shorten the Housing's Axle Tubes and use Stock or Aftermarket Axles for a 84-87 GN/GrandNational / T-Type / 442/HO. These Axles have 5" X 4.75" pattern.
A member on MonterCarloSS.com said someone makes the conversion UCA/UppercontrolArms for B-body to G-body Rear swap.
I think the B-body Rear is 3" wider than G-body, you could also use Rims with more Offset/BackSpacing if you don't want to narrow the Housing.
MikesMontes.com has a few 8.5" G-body Rears for sale. Last time He quoted $650 for an Open Diff Rear.
Also check 'For Sale' sections at:
Mailburacing.com
Turbobuick.com
Montecarloss.com
http://www.maliburacing.com/tech_rearend_swaps.html
http://www.maliburacing.com/rearend_guide.html
