Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 8.5 GM 10 bolt posi
Old 12-25-2003, 10:21 PM
musky2 musky2 is offline
8.5 GM 10 bolt posi
While changing tire on rear end ; I noticed that the wheel was turning but the other side wasnt because that side was sitting on the ground. It has the ( limited slip fluid only tag) , I know that doesnt mean anything. Took the cover off and every looked good and it had the plates and s spring. Now , because its been sitting a while or does the fluid make it work?
