8.5 swap: is my driveshaft too long? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-27-2005, 09:50 PM
malibu68's Avatar
I have a 68 chevelle with a th400 and an 8.2 rearend, i had the driveshaft made and it works good, there is alot of play in it tho, I am goin to swap my rearend for an 8.5. will my current driveshaft be too long? i heard that the difference is about an inch, if so i will be fine, except for the ujoint i think. Does anyone know forsure what the difference is between rearends and the driveshaft?
Old 03-27-2005, 10:09 PM
1982 SS's Avatar
Flamethrower
Last journal entry: More Cooling fan pictures.
What vehicle is the rear coming out of?
Old 03-27-2005, 10:15 PM
malibu68's Avatar
im not entirely sure, i need an 8.5 with coil over, 68-71 a body i hope
Old 03-28-2005, 12:30 AM
My 8.5" 10-bolt (out of a 2000 blazer) is 12" from axle centerline to the yoke centerline.
Old 03-28-2005, 03:41 PM
lucky lucky, those 8.5 10 bolts are hard to find in the S-10's. I gave up finding one for mine and got a ford 8.8
Old 03-28-2005, 06:25 PM
It took me a long time and many trips to look at "8.5inch" axles that were really 7.63" axles. The only thing that didn't bolt up on my 87 was the e-brake cables and the driveshaft needed to be shortened 1" (which is why I know how long the 8.5" is from yoke to axle centerline ).
10 bolt rear end question 8.2 or 8.5 ?? nheron Transmission - Rearend 6 03-02-2008 09:16 PM
10 bolt rear end question 8.2 or 8.5 ?? nheron Introduce Yourself 1 09-14-2004 10:26 PM
1989 Camaro Engine Swap Help! rollin89camaro Engine 2 10-03-2003 12:11 AM
1991 chevy 4wd V6 swap to V8 Michael Breaux Engine 3 10-20-2002 03:48 PM
8.2 and 8.5 chevyelc81 Transmission - Rearend 4 08-03-2002 03:19 PM
