8.5 swaps - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-06-2006, 12:17 PM
Redman Racing
8.5 swaps
hello again,
I found a car and a truck at the local junkyark with 8.5 rears and I was wondering about the bolt up diferences. The car was a 79 buick sedan I think a skylark or a park avanue. And the truck was like a 80 somethin chevy suberban or maybe sumthin a little smaller and was wondering about internal parts, did some of them come with posi traction???. There was no tag on the truck but the was a tag on the car (2KA-B 054 2.41 1)????. And the other questrion is - I heard some of the s-10 8.5 are direct bolt in???????
Old 04-06-2006, 01:19 PM
Hippie's Avatar
Last journal entry: HEI comparison.
'71 through early '89 8.5's had 28 spline axles and later '89 & up had 30 spline otherwise the carriers were internally the same. 2.73 thru 3..73s used one carrier and 2.41 and 2.56 used a different carrier which requires a special gear set or a spacer to install lower gears. Many of them were posi.
Some later 4WD S-10's reportedly used an 8.5 rear axle but it is wider than a 2WD S-10 by a few inches if that's what you're asking.
Old 04-06-2006, 01:30 PM
GM didn't put any "Posi" (i.e. Limited Slip) diffs in any truck after 73. If it has a G80 RPO code the diff will be a Gov-Lock (Governor operated Locker).
Good luck finding an S10 8.5" if that is what you want...there aren't many out there.
Old 04-17-2006, 02:04 PM
Redman Racing
is there a problem with the gov-lock in higher horse applications.
Old 04-17-2006, 06:39 PM
I haven't had any problems behind my mighty 2.8L
Gov-locks have the nickname "gov-bomb" because they like to go KaBoom! The problem is the shock loading when they lock up. From what I have seen it is the case that fails and takes out the R&P and housing (sometimes) with it.
I will be replacing mine with something stronger after I swap in the 383.
Old 04-17-2006, 09:05 PM
curtis73's Avatar
Hates: Liver. Loves: Diesel
Last journal entry: 1999-2001: Getting it on the road
Wiki Edits: 16
Actually they're pretty easy to find. Any of the ZR2 trucks including the blazer had them; most with disc brakes to boot.
Old 04-17-2006, 11:30 PM
It depends on what you want. The ZR2 rear axle would be 8" too wide for the back end of my truck and a normal 4wd axle would have been 4" too wide. At that width you might as well get something easier to find out of a full sized car or truck.
10 bolt rear end question 8.2 or 8.5 ?? nheron Transmission - Rearend 6 03-02-2008 08:16 PM
10 bolt rear end question 8.2 or 8.5 ?? nheron Introduce Yourself 1 09-14-2004 09:26 PM
8.5 rear end robbysapien Transmission - Rearend 6 08-04-2004 10:00 AM
Hotrodders Knowledge Cluster: Front Clip Installs/Subframes/Frame Swaps Jon Suspension - Brakes - Steering 0 10-12-2003 03:56 PM
8.2 and 8.5 chevyelc81 Transmission - Rearend 4 08-03-2002 02:19 PM
