8.75 axle settings
just put my 67 8.75 rear together and not sure of what to set the passenger side axle adjuster at , i have found several different answeres that ranged from 3 to 23 and i set mine at 17 , the rear isnt in the car yet so if i need to adjust it tighter or looser i can do it easily Any help on this would be greatly appriciated. I have 4.10 gears in it and dont want to have it set wrong and have to replace parts because of a simple adjustment that was done wrong. thanks in advance
8.75 rear axle adjuster settings?
i just re built my rear . Its an 8.75 out of a 67 belvedere 11 , it now has a 489 case & 4.10 gears with locker . i need to find out what the axle adjuster is supposed to be set at (passenger axle ) i have found different adjustments ranging from 3 to 28 so i set mine at 17 backlash . am i wright or do i need to change it , can anybody help me with the propper backlash ? thanks in advance
ramman1500... you posted 2 questions on same subject in different thread.
one thread many years old, one new thread. I have gathered up your questions here in one thread. thanks...
At the Bonneville Salt Flats, first gear is known as 130 mph. |
Backlash has to be arrived at as well as preload on the side bearings.
You have to get the preload set first , then move the side adjusters the same amount each time you adjust, to get to the proper backlash.That way you maintain the preload amount as you move the carrier left or right to get the backlash set. I assume you used the pinion depth tool to set the pinion up , as that needs done first. Also the pinion should not be in when determining carrier side bearing preload, but obviously needs to be in when setting backlash. Once you get the side bearing preload, back one adjuster off, ( count the notches for reference ) to make it easy to drop in the carrier. then with the carrier back in, retighten the adjuster to the spot that you have referenced for the proper preload, then move the adjusters equally left or right to get your lash I hope this makes sense. I havent set one of those up in years. Big Gear Head is good at diffs and may have some tips as well.
Fact is stranger than Fiction |
| Self adjusting brake adjuster access | rustman | Suspension - Brakes - Steering | 11 | 05-27-2011 03:27 PM |
| Ford Ranger seat back adjuster | matt167 | Interior | 0 | 06-13-2010 10:46 AM |
| Uh-oh: which way did that star adjuster go? | hon_jr | Suspension - Brakes - Steering | 8 | 11-06-2007 04:39 AM |
| rear suspension/Welding on Rear Axle | redsin | Hotrodding Basics | 4 | 05-30-2006 08:25 PM |
| Rear End - 5 bolt axle shafts into 6 bolt rear axle??? | Blue Chevy | Transmission - Rearend | 0 | 06-07-2002 05:23 PM |
