-   -   The 8.8 brake option (http://www.hotrodders.com/forum/8-8-brake-option-43621.html)
5.0Falcon 07-17-2004 03:23 PM
Ok, so i just aquired a 8.8 mustang axle to swap into my falcon and my question goes to the brakes.
The axle needs a brake job (cylinders pads springs drums) from the backing plate forward and i was just curious as to how much more i would spend to convert to the SVO rear discs and if those parts are easily found.
Suggestions.....
KwikFord 07-19-2004 08:47 AM
expensive. :eek:
but check this link.
http://svo73mm.cjb.net/
mustangcobra351w 08-05-2004 08:41 AM
Get a 87 or 88 Tbird rear end. They have discs [8.8] but there about a inch to inch and a half wider.I believe it has to be a 4 cylinder tbird.
