The 8.8 brake option - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-17-2004, 04:23 PM
5.0Falcon's Avatar
WHY NOT?
Ok, so i just aquired a 8.8 mustang axle to swap into my falcon and my question goes to the brakes.
The axle needs a brake job (cylinders pads springs drums) from the backing plate forward and i was just curious as to how much more i would spend to convert to the SVO rear discs and if those parts are easily found.
Suggestions.....
Old 07-19-2004, 09:47 AM
New Member
expensive.
but check this link.
http://svo73mm.cjb.net/
Old 08-05-2004, 09:41 AM
mustangcobra351w's Avatar
New Member
Get a 87 or 88 Tbird rear end. They have discs [8.8] but there about a inch to inch and a half wider.I believe it has to be a 4 cylinder tbird.
