Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 8.8" Ford axle question...
Old 09-27-2012, 01:37 PM
big gear head's Avatar
big gear head big gear head is offline
High Performance Rear Ends
If you are using Explorer brakes then you will probably need the 7750 housing ends. The 8.8 and 9 inch 31 splines are the same. Yes, Moser will make the axles with 31 splines and make them fit the press on 9 inch Ford axle bearings. Tell them what brakes you are using and they will make the axle hang out fit those brakes. Just be sure that you cut the housing correctly so that the axles fit. If you cut too much or not enough then the axles will not go in all the way or there will not be enough splines in the axle gears.
