8.8 ford diff good/bad? - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-16-2008, 10:18 AM
427feracer's Avatar
First On Race Day
Hey,guys i have an 1984 ford pickup 1/2 ton and a 68' 390 with a C6 tranny.I was wondering how good a 8.8ford diff is and where on the third member case could I find a gear ratio?
Thanx, Your friend 427feracer
Old 01-16-2008, 08:56 PM
I've heard nothing but good things about the 8.8 rearends, it's supposedly a copy of the GM 12 bolt. They seem to be able to hold up to alot of HP in some seriously hopped up mustangs that I've seen drag racing.
Old 01-16-2008, 09:18 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
some info;
http://www.badshoeproductions.com/rear.html#8
may help you , mayb not
Old 02-08-2008, 12:23 PM
2oldskool55's Avatar
Piston Broke
RE:Gear Ratio
Its easy to find your gear ratio ,count the teeth on your pinion and then on the ring gear then divide the ring gear teeth by pinion teeth and you have your ratio.Example 30 teeth on ring gear 11 on the pinion 30/11=2.72 hope this helps
Old 02-09-2008, 04:44 PM
Last journal entry: more...
All of the 8.8's ive looked at have a tag on a passenger-side diff cover bolt. The bottom left of that tag has "#_##" or "#L##" if it has a locker from the factory. These three #'s are your gear ratio! Hope that helps!
Old 02-09-2008, 08:44 PM
life is a temporary assignment
This is the first time I use one,I will be putting it to the test.
Old 02-09-2008, 09:15 PM
Wiki Edits: 27
turn the drive shaft
with both wheels off the ground turn the drive shaft and count times to get the wheels to turn over If only one wheel turns turn the drive shaft until the one wheel turns ove 2 times. that will give you the ratio. the hot mustang guys use a girdle for the bearing caps.
Old 02-09-2008, 11:38 PM
I heard of turning the two wheels together,And counting how many time the drive shaft turns.Make sure to mark the drive shaft. And that will give you your gear ratio
Old 02-10-2008, 10:12 AM
Last wiki edit: Calculating tire size
Last journal entry: Changes...
Wiki Edits: 2
Put the car in neutral and jack up 1 wheel at the back, try and turn it. If it turns easily you either have an open diff or your limited slip is completely shot. Turn the wheel a bit so the u-joint on the driveshaft is pointing straight up and down, and mark a chalk line on the tire pointing straight down. Turn the tire two revolutions and count how many times the driveshaft turns. That is your ratio.
If you have a limited slip diff you will need to lift both wheels off the ground, and do it exactly like I said above but only turn the wheels one revolution.
Old 02-10-2008, 10:26 AM
I thought it was one turn.
Old 02-11-2008, 07:59 AM
RippinRon's Avatar
One turn if it has posi, two if its open.
Old 02-12-2008, 09:33 AM
sharpe427's Avatar
The 8.8 is pretty stout with a little help. #1 is to replace the stock plate diff cover with a stronger unit to stop the flex. Summit sells these pretty reasonably. For crazy torque numbers, you may consider a c-clip eliminator kit as well.
List all of your cars HERE! Carbed95GT Hotrodders' Lounge 289 11-09-2011 07:43 PM
ford 8.8 or 9" stickysilverbird Transmission - Rearend 15 01-12-2008 11:04 AM
Ford 8.8 rear and C4 or C6 trans in 46 Ford... 46FordSuperDeluxe Transmission - Rearend 9 04-27-2007 06:59 AM
8.8 ford vs 8.5 chevy oldsmo Transmission - Rearend 4 05-21-2006 11:49 PM
Which 8.8 diff is more desirable? lebedkin Transmission - Rearend 0 02-10-2005 02:17 PM
