8.8 ford vs 8.5 chevy - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-18-2006, 10:21 PM
Redman Racing
Which rear would you consider stronger?? In stock form and or modified.
And has anyone modified an 8.8 ford to fit in a g-body???
Old 05-19-2006, 04:28 AM
curtis73's Avatar
Hates: Liver. Loves: Diesel
Wiki Edits: 16
The 8.8" ford is basically a stolen copy of the 12 bolt GM, so the 8.8 gets the nod for strength. The 8.5 is only a touch weaker than a 12 bolt though.
For ease of transplant I would do an 8.5 with a couple upgrades. I think you'll get the same strength with less money in the long run.
Old 05-19-2006, 08:45 PM
S10xGN's Avatar
Gotta love a turbo!
You can find a bolt-in 8.5" rear from '84 - '87 turbo-Buick and Olds 442 cars. The Olds had a 3.73 gear while the Buicks had a 3.42 gear. It's unlikely you'll find one in a boneyard so they'll cost you, (usually around $800.00) but 90% of them had a posi unit...
Russ
Old 05-20-2006, 03:58 AM
It depends on what 8.5 and what 8.8...
Older (pre~88) 8.5's came with 28 spline axles. Newer ones (like the 2000 Blazer one in the back end of my truck) had 30-splines.
8.8's came with both 28 and 31 spline axles depending on what it was under.
Old 05-21-2006, 10:49 PM
Redman Racing
well in that case I would have to say both with 28 spline. This isn't something that I am trying to do at the moment but thought it would be interesting conversation.
8.8 Ford rear end in my 79 G body Malibu 79 Malibu327 Transmission - Rearend 4 05-20-2007 02:26 PM
Ford 8.8 experts help! Did I get ripped off? macx Transmission - Rearend 3 02-07-2005 12:05 PM
Ford or Chevy Engine CustomFord Engine 28 01-19-2004 05:03 AM
ford and chevy t-5's...whats the diff? slammedchevy86 Transmission - Rearend 1 04-02-2003 05:13 AM
ford maverick to chevy 350 conversion 10 sec? cuda66 Hotrodders' Lounge 4 10-22-2002 02:24 PM
