8.8 off-set install in a 31 ford
Hello, does anybody know if a ford 8.8 off-set diff. will work in a 31 ford while using buggy type springs ? The present width is almost perfect for the car so cutting ain't gonna fix it,,,thanks for the heip.
rear width
There are different width's of 8.8. 87 and later 80's Mustang are narrow. You can get 2 ranger 5 bolt axle shafts . the short side ( they are different left to right ) . then trim off the old brackets and install the kits for buggy spring brackets, Lincoln Mark from the 80's disc brakes bolt on, Lots more 8,8 info on the later mustang forums.
when you say buggy, will the center of the spring or the ends of the spring on the rearend? /\ or \/
off set rears
thanks for the info, I live in Montana which makes availability of parts a problem, finding one of what - ever youre looking for can take time ,, but two,, might be a problem,,
thanks again,,,Jim
buggy spgs
the end of springs attached to axel housing , the center then attached to crossmember
| Anyone install a lates model Ford 3.8L? | CALI4N1A | Engine | 2 | 01-26-2011 02:24 PM |
| looking to install a radio in a 40 ford | coupedup | Electrical | 1 | 06-05-2009 07:59 AM |
| 84 Z28...what do i need to do to install ford 9"? | Rubberman2003 | Transmission - Rearend | 3 | 09-24-2003 06:45 AM |
| JAG REAREND INSTALL 56 FORD F-100 | Beedog69 | Transmission - Rearend | 2 | 07-11-2003 05:46 PM |
| 5.0 ford install | gerry | Engine | 1 | 06-18-2002 01:48 PM |
