8.8 Rear End - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-04-2012, 03:32 PM
Mac88's Avatar
"Drive It Until It Breaks"
8.8 Rear End
I need some more advice while I'm swapping out the rear-ends on my 88GT. I'm swapping them out because I found one that already had the gears I want (3.73), and it was cheaper than having a shop take out my current 4.56s and put in 3.73s. But anyway I have two questions:
1) Normally you mark you driveshaft to make sure it goes back in the correct location so as to keep it balanced. Since I'm putting in a different rear-end, how do I know what position to put the driveshaft in after the rear-end is installed?
2) I see some type of weight or something on the rear-end I'm pulling out. Does anyone know exactly what it is? I would research it, but I don't even know what to search for.
I'm attaching pictures to show what I'm talking about.
ID:	65803   Click image for larger version
Old 06-04-2012, 04:08 PM
The weight is a 10lb damper that doesnt work anymore if you change the gear ratio. I take em off but keep the pinion snubber. You'll need two 3/8 bolts about 1.5inches long to reattach the snubber.
The yoke can be put on 4 ways so you'll just have to see if it vibrates after install. If it does, then shift it one position and try again. If the vibration wont stop, get your driveshaft balanced if you have aluminum, or get the Ford Motorsport aluminum shaft.
Old 06-04-2012, 04:47 PM
Mac88's Avatar
Re
Thanks fir the information. That makea alot of sense. I can take the snubber off a parts car I have out back.
1953 Buick Special-front end rear end?? mbjeep Suspension - Brakes - Steering 8 12-06-2009 06:32 PM
stock 63 chevyII rear end vs. s-10 rear end david6chevy Transmission - Rearend 3 08-17-2009 04:36 AM
Gm 12 bolt truck rear end vs. car rear end '54 Pontiac Transmission - Rearend 6 02-05-2009 05:17 PM
4x4 12 bolt rear end same as 2wd rear end??? Ed ke6bnl Transmission - Rearend 2 05-24-2008 02:25 PM
Ford 9" rear end vs stock 89 chevy truck rear end jimmy p Transmission - Rearend 2 12-07-2005 03:28 AM
