8.8 rear end "locked" - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-08-2012, 01:29 PM
Hi Guys
Im installing a explorer 8.8 axle under my car over christmas,was speaking briefly to someone over the phone and they said something about because
my car only weighs 2600lb that this could cause the rear end to be permantly "locked" around corners. I dont really understand why,can any of you guys explain to me what he was on about? and what options I have to correct this?
Thanks in advance!
Old 12-08-2012, 01:32 PM
123pugsy's Avatar
Last wiki edit: Metal shaping
Last journal entry: SEAM SEALER
Wiki Edits: 29
Well, you got my curiosity. Hopefully someone can shed some light on this.
Old 12-08-2012, 01:36 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Originally Posted by dave350v8 View Post
Hi Guys
Thanks in advance!
It won't happen unless you have welded spider gears or a spool- providing the diff isn't broken/defective.
Old 12-08-2012, 03:13 PM
big gear head's Avatar
High Performance Rear Ends
The Explorer rear end should have a Trac Lock differential, which is a clutch type limited slip differential. You shouldn't have any problems out of it.
Old 12-08-2012, 04:04 PM
Banned
because your cars weight might not be enough to cause the diff clutches to slip.. 2600 lb / 4 wider tires will help as the footprint will grip the road..
the wifes sporttrac is tail happy in the rear in the rain and the v6 isn't all that powerfull..
Old 12-09-2012, 02:45 AM
Thanks for your input guys, apparently I might need to grind down the "springs" down a bit to help! Hopefully you are right and it should
be ok as it is!
Old 12-09-2012, 07:55 AM
Wiki Edits: 27
test drive it
I wouldn't modify anything untill I had some miles on it under varying conditions. The old detroit lockers use to make noise when making sharp turns in a parking lot, just the way they were. Just be careful test driving it in the rain on smooth pavement until you know how it will handle.
Old 12-09-2012, 09:08 AM
[QUOTE=timothale;1620757]I wouldn't modify anything untill I had some miles on it under varying conditions. The old detroit lockers use to make noise when making sharp turns in a parking lot, just the way they were. Just be careful test driving it in the rain on smooth pavement until you know how it will handle.
Thanks will do, I wandering if its something I can sort out once Ive fitted it to my car,dont really want to remove axle again
Old 12-09-2012, 10:06 AM
You can't grind the springs in the Trac Lock. It has a sheet metal spring bent in the shape of a S, not the 4 coil springs like the Eaton Posi or 5 springs like the Auburn. It shouldn't be a problem. Just be careful when turning corners on wet roads, otherwise it should be fine. If you want the cluthes to slip more then use more of the Ford limited slip oil additive.
Old 12-09-2012, 10:56 AM
Thats great info! Thankyou
Old 12-09-2012, 11:54 AM
S10xGN's Avatar
Gotta love a turbo!
I added the "truck" version of the S-spring in my S-10 when I put new clutches in her 8.8", now she'll "chirp" around a tight corner if the pavement is good and hot. Hmmm, my '98 Dakota R/T does the same and it's never been apart.
Russ
Old 12-23-2012, 10:35 AM
cranky1's Avatar
Just stuck
My Durango has a Track Lock in it....I really don't care for the design of that type of LSD much. Bought the vehicle new and it started acting up (making noise) at 25k miles so I changed the oil in it and added the recommended limited slip additive and within 4k miles, it was making noise again only louder. Drained it out and cleaned out the crud again and this time added STP to the gear lube. Yup, you read that right. 40k miles later and it still works fine and is quiet.
~54" wide, 8.5" 10 bolt rear end question superherbie Transmission - Rearend 3 10-06-2009 07:31 AM
"roaring" noise in the rear end of my 1998 mustang 223Mustang Transmission - Rearend 1 05-02-2009 12:27 PM
5 on 5" rear end swap in my '62 GMC - 10 bolt vs 9" vs Dana 44 Chuck78 Transmission - Rearend 8 07-22-2008 11:01 PM
9" rear end "drag race gear" what does that mean? 84Z Transmission - Rearend 2 01-29-2006 05:08 PM
"roaring" noise in the rear end of my 1998 mustang oldsgeek Transmission - Rearend 10 12-26-2004 09:14 PM
