8.8 rear Mustang / Explorer - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-05-2009, 04:11 PM
35prog's Avatar
Last journal entry: More photos
I was given an 8.8 axle awhile back. It was supposed to be from an Explorer. However, I think it is a Mustang rear as it has "ears" on top of the pumpkin. It is a disk brake and is supposed to be a 3:73 traction lock. I know that the Explorer is prefered due to the 31 spline axles.
My questions are:
1. Is the width of the Mustang axle housing the same width as the Explorer?
2. I have seen that the center section is offset to one side, I understand this is the same with the explorer rear end? Is this correct?
3. When used is a street rod application (383 stroker with 700r4 trans in a 35 Chevy Master Coupe) will the Mustang unit be suitable? Or should I upgrade to the Explorer rear.
4. Also have heard that others have used another short axle to center the carrier. It appears this makes the rear end 57 inches wide from flange to flange. Can anyone give me info on am approximate cost to do this.
Thanks
Old 11-05-2009, 06:39 PM
hi
The explorer would be better 31 but not alot just under 60". THe mustang is 28 spline and I think most are a 4 lug but might be wrong. The mustang is wider but not sure how much. I have seen lots of big hp mustangs on stock 8.8 28. I have also seen lots of hp on a chevy 8.5 that is not close to the 8.8. To have one cut down might be 3-400 and would not have an axle. The biggest problem with the 8.8 is it has thin wall tubes and should be tiged. I would also tig the center to the tubes. Get you perches from curry the 8.8 is 3 1/4 not 3.
Ford 8.8 Explorer rearend spring perches? fasteddy51 Suspension - Brakes - Steering 6 09-17-2009 10:54 AM
What do you think of a '96 Ford Explorer rear end for a street rod? jpd37 Transmission - Rearend 16 06-10-2009 06:49 PM
8.8 Ford Explorer rearend-Tools Needed for Removal? fasteddy51 Transmission - Rearend 2 05-01-2009 05:32 PM
Explorer Disc Bbrakes on a 9" Ford Rear End Mustangsaly Suspension - Brakes - Steering 2 10-31-2005 04:18 PM
79-93 Mustang 8.8" Rear Differential Width From Hub-To-Hub nightrain_rod Transmission - Rearend 1 12-04-2003 07:59 AM
