8/8 split rocker ratios - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-26-2008, 12:46 PM
I have a high energy 268H in a sbc with 882 heads home ported with 1.94I. It is a split profile cam and with my setup I feel that I could benefit from running a 1.6 rocker on the exhaust. That would make it 218/218 .454/.483 versus 218/218 .454/.454. This should help with exhaust gas scavenging. Has anyone ever tried this?
-Ray
Old 05-26-2008, 01:21 PM
carsavvycook's Avatar
My 2 cents worth
Wiki Edits: 3
Yes I have tried this but after checking the rocker to valve geometry, I had to change the push rods to shorter ones on the exhaust to get it back in alignment in the center of the valve. It was more hassle than it was worth for the net gain, and did not seem to make any difference. I wound up ordering a different cam profile for the next race.
Old 05-26-2008, 02:55 PM
techinspector1's Avatar
Senior Curmudgeon
Wiki Edits: 326
In most comparisons I've seen, the 1.6 rockers look like much ado about nothing.
Old 05-26-2008, 03:13 PM
F-BIRD'88's Avatar
Yada Yada Yada
You'd probabily find more of a power gain by using the 1.6 rockers on the intake side. The exhaust responds more to valve timing duration changes than to lift changes.
Old 05-26-2008, 06:35 PM
good advise, right on the money.
rocker arm ratios charlp703 Hotrodders' Lounge 4 01-05-2007 04:26 PM
split rocker arm.....? "SLOWMOE" Engine 7 07-28-2004 07:18 PM
Rocker ratios on small block chevy. KeithB123 Engine 4 12-01-2003 07:36 PM
rocker arm ratios molevolent_creations Engine 2 10-26-2003 05:09 PM
Rocker arm ratios chevypunk Engine 5 04-14-2003 10:02 AM
