8.96 run - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-27-2002, 08:23 PM
Post 8.96 run
have a 84 full size c-10 chevy truck wieghing 5000lbs. went to music city raceway and run an 8.96 in an 1/8 mile track. could be wrong, but for the wieght and size thats pretty dog gone good. could use more info on getting it quicker without nitro or a blower.
Old 08-27-2002, 09:29 PM
Post
Man! you must have been smoking I don't know how the 1/8 mile compares to the 1/4 but that sounds pretty quick. I'd stick with what you got.
[ August 27, 2002: Message edited by: hcheetwood ]</p>
Old 08-28-2002, 08:36 AM
Post
What gear are you running? Is your timing set to the point it starts banging as you cross the finish line? If not set it at that point and you'll get the most out of what you have. What engine are you running?
Old 08-28-2002, 12:38 PM
BigBlockBabe's Avatar
Missing You
Post
8.90s ain't too shabby. My buddy's Chevelle with a 402 ran 8.90s in the 1/8th. What's was your 60ft time?
Old 08-28-2002, 06:48 PM
Post
thanks for the vote of confidence. i,m running a 373 gear and my 60 ft. times are 1.95 right know. my timing i,ve tried advancing it and run 9.11s. so i tried retarding it and it worked better. still have to remove some leaf springs for weight shift(hopefully it,ll help more) and uncap the headers and see what happens. the motors a sb350.thanks fellas
Old 08-28-2002, 07:02 PM
HemmiGremmie's Avatar
Last journal entry: 52 truck
Post
MAN!
Im scared to take my Gremlin now. Im thinking it will only run about 9.30-10's in the 1/8th w3ith the setup I have. And its tubbed and everthing. Makes me feel kinda wimpy. :o .
Thats a great time though. I dont know what more you could do except add headers, chip(if ones made), deeper gears or some kind of msd box for better spark. Sounds great to me. HG
I was built with the body of a God! To bad it was buddah.
Hemmies rat journal below.
Old 08-28-2002, 07:03 PM
Post
Oh yea. HCHEETWOOD.
For 1/4 mile times, they say add about 4 seconds to your 1/8th mile and its a close guestimation. HG
Old 08-28-2002, 08:24 PM
Post
What motor and trans have you got and what are your mods?
Old 08-29-2002, 04:56 AM
Post
Im not sure if your asking me or Joe, so in case, Its me, I'll give ya mine.
350, stock heads, flat top pistons yielding around 9-1 comp, small cam, 480liftX280 duration, Edelbrock intake, vacum advance 600 or 750 carb(not sure), dual point dist, stock exhaust manifolds running into sidepipes.
Tranny is a 2 speed powerglide with a stock convertor, 4.56 gears with 31 inch tall tires.
Id say the motor makes a conservative 280-300 horses, but the 2 speed tranny hurts me on takeoff with those big tires. HG
Old 08-30-2002, 06:10 PM
Post
in case your asking me i,m running a 350. 60 over stock crank(nf),stock x rods,baby dome pistons(kb) 882 factor heads fully ported,2.02 and 1.6 valves,heads and block have been saved done to get 64 cc chambers running 12 to 1 compression,1.6 roller rockers,294 duration cam with a 510 lift, holley street dominator dual plain intake(been ported and shaved to match heads), 750 edel. carb,350 turbo trans and a 373 pos unit.
Old 08-31-2002, 10:57 AM
Post
Joe...I am assuming you have headers,if not get some.To make it really quick in the 1/8 mile try some 4.88:1 or 4.56 gears for the strip and run your 3.73s on the street. After you get your spacers all set up and change the gears a couple of times you'll be able to do it in less than a hour.I use to do it every week on my Camaro only I had 3.55s for the street. Run some real sticky tires. You'll need them. The thing will be a rocket.
[ August 31, 2002: Message edited by: hcheetwood ]</p>
Old 09-21-2003, 07:33 AM
TurboS10's Avatar
Last wiki edit: Auto Terms and Definitions Used in Modern Engine T... Last photo:
Wiki Edits: 2
Originally posted by HemmiGremmie
Oh yea. HCHEETWOOD.
I have always heard, and it seems to hold true, that you add 50% of the 1/8 mile time and that will give you 1/4. Of course this is just a rule of thumb, and some combinations will vary a little.
Chris
Old 09-21-2003, 08:14 AM
dmorris1200's Avatar
doesn't play well with others
Nice run dude! Most of the guys I see running trucks have the hardest time with their launch. That's a great 60ft time. My budy ran his Valient Thursday night (street night) at our 1/8 mile track and pulled between 8.89-9.97 and he's got a pretty wicked 340 engine and 4.11 gears. Would make a nice run against your truck.
BUILT FORD TOUGH
Old 09-21-2003, 08:39 AM
TurboS10's Avatar
Wiki Edits: 2
Wow a full 1.1 second swing. Was that bracket racing?
Chris
Old 09-21-2003, 08:45 AM
Sorry Chris, my bad. Typo error there.
Should have said 8.89-8.97. Oops!
BUILT FORD TOUGH
