are 8" foam pads ok? - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-27-2013, 03:40 AM
cutthroatkid's Avatar
two cups of tea
Last wiki edit: Need more horsepower for my 305 Last photo:
Wiki Edits: 2
My polisher has a 7 in backing pad&I can't find 7 in pads nowhere local only the wool sonnets is it ok to use the 8 inch foam pads..as I can fins them locally.
Old 04-27-2013, 07:33 AM
Old Fool's Avatar
I have never used a bonnet, dont know how well they even work.
Old 04-27-2013, 09:22 AM
TucsonJay's Avatar
The 3-M foam pads I use are bigger than the backing pad.
I do trim the cloth backing off of the pad edges where it extends beyond the pad. If I am buffing in a corner or depression. that cloth backing can cut into the paint.
Otherwise, they are far superior to the wool, as they won't leave swirl marks.
I sand with 1200 meguires paper, then use a white 3-M waffle pad with their 06083 liquid compound in the purple bottle. It is expensive, but the work goes much faster than anything I have used in the last 40+ years!!!
If it is a dark color you may need a slightly better finish, so I go over it again with a softer gray waffle pad for a slightly higher gloss.
I will add that I use R-Ms DC92 clear.
Here is an example of the finish...
1/4 or 1/2 " Sew Foam? Coodeville Interior 15 03-02-2011 11:52 AM
Scotchbrite pads texczech Body - Exterior 13 04-20-2007 05:58 PM
Can I use the same pads? Malibucdl Suspension - Brakes - Steering 5 08-04-2006 07:45 PM
body pads beetle9 Body - Exterior 4 02-21-2003 04:09 AM
Hey croz look """"IMPORTS SUCK""" 78 monte Hotrodders' Lounge 14 08-30-2002 01:13 PM
