8" Ford Rear - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-02-2006, 12:04 PM
8" Ford Rear
I have an 8" Ford rear in my T- Bucket. I have a leaking rear wheel bearing seal. Once I get the axle out where is the seal? I really mean will the bearing have to come off to replace the seal or does the seal stay in the housing? If the bearing needs to come off I figure I may as well remove both axles and get both bearings replaced along with both seals.
Old 09-02-2006, 12:39 PM
the seals are on the outside of the bearings, so you don't need to remove the bearings to replace the seals, but if ones leaking why not do both, because you gotta open the diff anyways, and why not change the bearings while your in there too?
The money you'll save from servicing the diff twice will almost just pay to do it all the first time
Brendan
Old 09-02-2006, 03:08 PM
Thanks. That was what I was thinking.
Bill
Old 09-02-2006, 03:18 PM
The seal is a easy fix ... look at the diagram ...
Old 09-02-2006, 03:24 PM
Now that really helps. Thanks.
Bill
8.8 Ford rear end in my 79 G body Malibu 79 Malibu327 Transmission - Rearend 4 05-20-2007 02:26 PM
8" Ford Rear & Brakes GoodWood Transmission - Rearend 2 06-22-2006 03:45 PM
1945 ford p/u rear leafs,to keep or not to keep biglee550 Suspension - Brakes - Steering 8 04-25-2005 07:05 PM
Ford 7.5" Rear End Traction-Loc Install nightrain_rod Transmission - Rearend 2 12-30-2003 06:38 PM
rear differential for 46 ford rp1 Suspension - Brakes - Steering 1 09-08-2003 07:43 AM
