8" Ford Rear & Brakes - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-19-2006, 10:15 PM
Hi,
I need to replace the rear drums and shoes on my '31 A Coupe, but am having trouble determining what the rear is out of.
I have identified it as an 8" ford rear. It has 11" x 2" drums, with 5 x 4-1/2" bolt pattern, and 2-7/16" center hole.
The rear measures 57-1/2" flange to flange, and 52-1/2" backing plate to backing plate. The only identifying numbers on the carrier are 6-68, (or, if upside down) 89-9. There are no numbers on the axle housing, but the axles flanges say AB 35B. The drums are stamped 9 x 48 KH, FOMOCO KH (right side), and KH 726 B (left side), and the backing plates are stamped Bendix 305489-L.
The rear housing has a drain plug on the bottom, and the carrier has a fill plug on the driver's side.
Any help or suggestions will be GREATLY appreciated. Thanks.
Woody
Old 06-20-2006, 12:53 AM
aka Duke of URL
Those are Kelsey-Hayes I.D. Nos. Any large parts jobber should be able to convert them.
Old 06-22-2006, 03:45 PM
xntrik's Avatar
Save a horse, Ride a Cowboy.
Duke is correct.
I am not aware of any 8 inch Ford rear that came with 11 inch brakes.
I would compare the shoes to the 57 Ford factory items. Most Fords are similar for many years.
i got ford parts on my chevy rear axle roy383ci Hotrodders' Lounge 0 09-11-2005 03:31 PM
Front Disc Rear Drum Brakes bigjoedo Suspension - Brakes - Steering 2 07-02-2004 10:16 AM
ford 8.8 with camaro disk brakes terror385 Transmission - Rearend 1 05-08-2004 06:20 AM
Front drum "juice" brakes on a 32 Ford 32Steel Suspension - Brakes - Steering 9 03-03-2004 04:29 PM
Ford Ranger 8.8" Rear Disc Brakes nightrain_rod Transmission - Rearend 1 06-23-2003 05:48 PM
