8" Ford Rearend tube measurement for U-bolts - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-20-2010, 10:24 AM
I am having difficulty in locating proper u-bolts for the rearend that i am using in a street rod build. I feel like i have reasonable knowledge base when it comes to parts, but there appears to be no real clear source of knowledge for locating these.
The original u-bolts have an inner width of 2.875"(2 7/8"). So i order 3" u-bolts thinking they are center to center measurements. Wrong.
When i search u bolt sizes, some are inside dimensions, some are center to center, some are radius (round) dimensions.
There appears to be no standard. I hate to drop $40 on another set that still aren't correct. Does anyone know a specific u-bolt dimension i should look for or a supplier that can help.
The housing actually measures out somewhere around 2.890" diameter. But the 3" bolts are way too wide for the bottom bracket holes. I hate to open those up or try and weld and re-drill if I could just buy the right bolt.
Any help?
Thanks.
Old 08-20-2010, 11:28 AM
big gear head's Avatar
High Performance Rear Ends
I have a local truck spring shop that makes u bolts for me. I tell them what I want and they make them exactly like I tell them. If you have a shop like this around you then you might try them.
Old 08-20-2010, 11:42 AM
adantessr's Avatar
'23 T-Bucket Pickup
Last wiki edit: Troubleshooting ignition Last photo:
Wiki Edits: 3
Even our little town of So. Charleston , WV has spring shop . If you can't find anything local . We have West Virginia Spring and Radiator that will make anything you need and send it to you . Check the anywho directory online and you should be able to find what you need locally . anywho.com
Ford Steel Wheel Tech wheelkid General Rodding Tech 9 01-07-2007 07:31 PM
'53 Ford rearend info HELP! yelton57 Transmission - Rearend 3 05-27-2006 10:13 PM
JAG REAREND INSTALL 56 FORD F-100 Beedog69 Transmission - Rearend 2 07-11-2003 06:46 PM
9" ford rearend 37 ford melbishop Transmission - Rearend 3 12-09-2001 10:15 AM
ford rearend for 33? nick Transmission - Rearend 2 11-06-2001 11:58 PM
