8" maverick differential makes a bang shifting from drive to reverse - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-20-2012, 10:47 AM
Bobs36ford's Avatar
Last journal entry: Video of new upholstery
Hi
My 36 Ford with 350 chevy engine and a 350 turbo trans and 8" maverick rear end makes a loud bang when shifting from drive to reverse. It does not make a noise when shifting from reverse to drive. Help!!
Old 02-21-2012, 09:18 AM
S10xGN's Avatar
Gotta love a turbo!
Originally Posted by Bobs36ford
Hi
Checked your u-joints yet?
Russ
Old 02-21-2012, 11:37 AM
Bobs36ford's Avatar
Russ
No i have not...will check them first.
Thanks
Bob
Old 02-21-2012, 04:41 PM
Wiki Edits: 49
A bad "U" joint will make a banging or thud type noise when the driveshaft changes directions. Sometimes its just one way and sometimes both, depends on how bad and exactly what the problem with the "U" joint is. What you describe doesn't sound like a rear end problem.
Centerline
HotRodsAndHemis.com
"When buying a used car, punch the buttons on the radio. If all the stations are rock and roll, there's a good chance the transmission is shot." - Larry Lujack
TH350 Reverse Drive Only ***? DCheck_OleBlue Transmission - Rearend 6 01-26-2009 03:29 PM
Reverse but no drive or low ethel Transmission - Rearend 3 10-22-2008 09:38 PM
1st and reverse no drive or 2nd NIWROC Transmission - Rearend 4 12-22-2005 02:04 PM
Why does it stall when shifting into reverse? Fastncrazy General Rodding Tech 3 03-08-2004 09:38 PM
I'm confused about reverse- pattern shifting. ss crazy Transmission - Rearend 5 07-14-2003 05:24 PM
