8 Position Cadillac seat for 37 Chevy coupe -Stumped - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 01-16-2014, 11:07 PM
Please keep us informed as to your efforts, and results; your success could be a big help to others trying to use later model seats in their street rods. As you know, more, & more vehicles are using multiplexed wiring architecture for their accessories to simplify wiring, keeping costs & weight down. To adapt the newer hardware to our older rods will continue to tax our creativity.......
  #17 (permalink)
Old 01-17-2014, 05:36 AM
EOD Guy's Avatar
I'm not clear on your drawing...... Your drawing indicates each micro switch controls two movements or 8 actions. What are the other actions? How many motors are they controlling?
Grn & Pnk = FWD
Grn & Blk = BACK
Red & Blk = DOWN
Red & Pnk = UP
Yel & Pnk =
Yel & Blk =
Blu & Blk =
Blu & Pnk =
  #18 (permalink)
Old 01-17-2014, 06:20 AM
EOD Guy's Avatar
This is what I have, which indicates the switches are NO/NC, single throw
Name:	Caddy Seat 1.jpg
ID:	113377   Click image for larger version
Name:	Caddy Seat 2.jpg
ID:	113385   Click image for larger version
Name:	Caddy Seat 3.jpg
  #19 (permalink)
Old 01-17-2014, 11:29 AM
EOD Guy's Avatar
If you if fact only have 3 motors let me know, I'll try and help out.
  #20 (permalink)
Old 01-17-2014, 05:58 PM
EOD Guy's Avatar
Here's what I came up with for the fwd/back seat motor. I assumed the Blk wire was the ground and was hooked to the normally closed terminal on the switch. You need to unhook the NC terminal on the switch, you only need the NO portion of the switch to energize the relays. The relays will reverse the polarity to the motor just like the original switch etc......
  #21 (permalink)
Old 01-18-2014, 09:52 AM
LATECH's Avatar
Last journal entry: GTO Reproduction Hood
One of the low trim level versions of he CTS came with Non memory drivers seat.The harness was wired with the heavier switches to hook to battery voltage. Switches were heavier to accommodate the current rating. Also the switches would interchange in the seat .
I would shop for a wreck with the non memory harness.
Maybe LKQ or a U pullit yard? Just sayin
Fact is stranger than Fiction
  #22 (permalink)
Old 01-18-2014, 10:11 AM
51fordnut's Avatar
Solved
EOD Guy, thanks for your help. I didn't see your post till this morning. I figured thing out yesterday. So, what I have is 4 motors (2 positions per motor) 8 positions. The problem that I had was the 2 wires that were common to all 4 switches because when I hooked them up to the relays the switches were not independent and would cause all motors to go at the same time regardless of what position I selected. If I was running 12v power through the switch lets say to the 4 colored wires (green, blue, red, and yellow) then when I activated the switch, it would send the power out the pink and activate the 4 up/forward relays. Vise versa for the down/back position. If I tried to run the switches as a ground circuit, the same thing happened. I just didn't have enough wires coming out of the switch panel.
Here is how I solved it. I took the switch panel apart (see attache photos) and found the pink and the black mapping on the circuit board, Then I used a small dremel tool to cut the mapped circuit and separate each switch. Then I left myself enough space next to the switches to clean a new spot off so I could solder on/connect a black and a pink wire to each switch. This would give me the 2 wires per switch that I needed to complete the circuits independently. After I soldered it all up, I added some liquid electrical tape to each contact, zip tied all the wires and put the switch control back together. In the end, I used the switches to complete the ground circuit for the relays.
ID:	113649   Click image for larger version
ID:	113657   Click image for larger version
ID:	113665   Click image for larger version
ID:	113673   Click image for larger version
  #23 (permalink)
Old 01-18-2014, 10:13 AM
51fordnut's Avatar
Here is my new drawing of how it is laid out. (sorry, not a great drawing)
  #24 (permalink)
Old 01-18-2014, 03:57 PM
EOD Guy's Avatar
Good to hear you got it figured out
  #25 (permalink)
Old 01-18-2014, 06:20 PM
Very clever problem resolution! How many relays are you using in this configuration?
  #26 (permalink)
Old 01-19-2014, 10:33 AM
51fordnut's Avatar
Crdnblu - I used 8 relay in this setup. It requires 2 relays per motor, 1 for forward/up and 1 for back/down. Here are a few pis of the finished project.
ID:	114057   Click image for larger version
ID:	114065   Click image for larger version
  #27 (permalink)
Old 01-19-2014, 04:22 PM
EOD Guy's Avatar
Are the memory switches functional? I could see where they could be re-purposed for Automotive things.....like power window and power lock switches.
  #28 (permalink)
Old 01-19-2014, 05:22 PM
EOD Guy's Avatar
I drew it up for you, I think this is how you have it wired...... terminals on the relay, 85 and 86 are interchangeable (each are one side of the coil)
The Following User Says Thank You to EOD Guy For This Useful Post:
51fordnut (01-19-2014)
  #29 (permalink)
Old 01-19-2014, 07:48 PM
51fordnut's Avatar
WOW, EOD GUY!!!!!!! That is really cool that you drew that up for me!!! Thank you very much! Now I can add that to my little book of wiring know how instead of all my little drawings... I'm beside myself that you took the time to do that!
Yes, I think a person could very well hook those other 4 little micro switches and use them to run other things. They were all just momentary on switches.
Thanks again! BTW, what program do you use to do that?
  #30 (permalink)
Old 01-20-2014, 03:03 AM
EOD Guy's Avatar
I used power point, then saved as a jpeg. It only took about 20 min.
TH 400 Cadillac in a 40 ford coupe Footstomper Transmission - Rearend 6 04-14-2011 08:26 PM
My Learning Project : 1970 Cadillac Seat Cover Coodeville Interior 3 10-16-2010 09:13 PM
1970 Cadillac Seat? Coodeville Interior 5 01-16-2010 01:32 AM
1958 Cadillac Coupe Deville bigwoodbass Engine 3 03-25-2007 07:36 PM
1965 Cadillac Coupe DeVille Fragzem Transmission - Rearend 3 07-09-2005 09:29 AM
