8" Rear end Bearings - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-26-2007, 08:39 PM
I have an 8" rear end from a Ford Granada and one of the wheel bearings is leaking. How do I replace it. Do I remove the rear cover and remove the pins? or can I remove the 4 bolts in the backing plate and remove it that way?
Old 05-26-2007, 09:41 PM
Jack the car up. Secure it ... with jack stands. Remove the tire/rim and then the brake drum. Remove the 4 bolts and slide the axle out ...
this is a saver.... GM build codes TooMany2count General Rodding Tech 24 11-23-2009 09:36 AM
Rear end ID ctown Transmission - Rearend 1 05-15-2006 10:20 AM
S-10/Camaro Rear End slaveforthewave Transmission - Rearend 7 02-20-2006 01:44 PM
1975 8.5 rear end camino_man Transmission - Rearend 6 09-18-2004 05:32 AM
Question about 12 bolt rear end Roy_67_SS350 Transmission - Rearend 6 12-14-2003 11:57 AM
