8" third member swap - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-16-2006, 07:29 AM
blacksunshine's Avatar
Bleed Blue
The one thing I know about rear ends is that when they go out and lock up on you, its no fun. This is why I have never touched gear swaps, or any diff for that matter.
But im over my fear of screwing it up and locking the back wheels solid..I have a 69 Torino, just a lil 302 and c4 in it. It has the 8" with a granny 3.00:1 gear, and actually I can still do a burn out, and freeway cruising is at a nice low RPM. I think 3:55's would wake it up just a little bit and not kill my freeway fun. Here's where I need help, if im not mistaken I should be able to pull a 3rd member out of a 3.55:0 ford 8" car / truck and it should be a direct swap right...or should I just look for a complete axle, or maybe a 9" swap. ??
Old 06-16-2006, 08:06 AM
TooMany2count's Avatar
A Half Crippled Old SOB....
Last wiki edit: GM RPO build codes Last photo:
Location: Cahokia,IL..... Donate Blood Products & Sign your DONORS CARD
Wiki Edits: 5
8inch came in only cars i believe & the dead give away to tell an 8" from a 9" is on the 3rd member the 2 bolts on the very bottom of the 9" u HAVE to use a wrench to remove it. also the eight inch came only in 28 spline
good info on this page about 8" & 9" ford rearends
as for removing its fairly simple. put the car on jackstands, remove ur tires & brake drums. disconnect ur driveshaft, (u might have to disconnect ur brake lines at the wheel cylinder), unbolt the 4 bolts u see on the backing plate, these hold the axle/bearning in. then give the axle a good pull, if it doesnt come out try this. put the brake drum on backwards & tighten up the lugnuts just enuff so the drumm w/still slide on the lugs & then w/the drum as far in as u can get it give it a hard yank. it should act like a slide hammer & pop the axle/bearning out. w/the axles removed start to unbolt the 3rd member, here's a hint:leave 1 or 2 nuts on(but loose) on the top of the 3rd memeber, this way it wont just fall out on u. when all the bolts are off take the top 1 or 2 off & carefully pull the 3rd memeber out. u may have to hit it w/a hammer or use a screwdriver or chisel to break it loose. BUT becarefull when it breaks loose because those thing can & will hurt u ask me i know.
when u put it back together i would replace the seals on the axles & if u dont want to or cant get a 3rd member gasket a good ATV sealer will work just fine. put the 3rd member in the housing, then slide ur axles back in, tighten up the axle bolts, add ur rearend grease, install ur driveshaft, hook up ur brake lines & bleed them(<~~IF u had to disconnect them), & adjust ur brakes & u should be good to go. once the car is in the air i used to do this job in less then hour. normally u'll spend more time jacking the car up & getting ready to do the job & the clean up then u'll have in replacing ur parts..joe
Old 06-16-2006, 08:53 AM
Bleed Blue
Awsome!! Thanks Joe, thats good info.
Now all I have to do is find a 3rd member w/ a decent ratio.
Old 06-16-2006, 09:45 AM
Bleed Blue
Wait...so this means that the 8" and 9" axle housings are the same? all I would have to do for a complete 9" rear is swap to a 9" third member and replace my axle's with 31 spline axles?
Old 06-16-2006, 10:21 AM
Wiki Edits: 27
9 's are bigger
9's and 9' 3/8 which were used in monster lincolns can be interchanged in a lot of housings with a little grinding but 8's and 9's are different.
Old 06-16-2006, 10:23 AM
Wiki Edits: 5
NO they are COMPLETELY different
NO but u could swap the complete rearend out and some should be a direct bolt in. HERE's a good site that'll tell the widths & what kinda car to find a 9" in....joe
Old 06-16-2006, 10:31 AM
Bleed Blue
Yup, I just read that in that article. This is perfect info. Thanks guys.
Old 06-16-2006, 10:35 AM
The 8" and 9" Ford rears share a lot of common parts. For example, a Granada rear used the same axles, brakes and tubes in the 8" and 9", the only difference is in the center section of the housing. I have replaced 9" Mustang axles with axles from a 8" rear from the same model.
Old 06-22-2006, 03:53 PM
xntrik's Avatar
Save a horse, Ride a Cowboy.
I wouldn't worry about breaking an 8 inch rear until you had 300 hp to the tires, super traction, and were doing severe clutch drops or using a trans brake. Most 8s have the same axles as the light 9s. 8s are getting very popular in the street rod crowd because they are very stout, cheap, and easily available in the popular width, e.g. 70s Granada. $100 wheel to wheel, or $50 or less for the center chunk, unless it is a 70s Traction-Lock which brings $300.. avoid the Equa-Lock if possible..... no parts available.
Grab a 3.50 gear from a mid 66-67 Fairlane OD car, or a 3.55 from a V6 Mustang II. Hope for a Traction Lock differential.
Old 06-22-2006, 04:02 PM
Bleed Blue
Yeah, im not worried about breaking an axle with the lil 302. I hear alot of 9"s have 28 spline axles like the 8"s. I'll just find me a 8" third member with a 3.55 like you said and go from there. Thanks for the help !!
Cam swap Questions wayfast77 Engine 3 10-18-2006 04:52 AM
68 mustang 8" to 9" swap fla68rustang Transmission - Rearend 5 08-01-2005 07:49 AM
Found this site looking for swap info Roadrod Introduce Yourself 1 11-07-2004 10:16 AM
Rear 3rd member swap 53Z Transmission - Rearend 4 10-12-2002 03:05 PM
